Check System Requirements
Oracle has certified the following requirements for the
Oracle® Communications Report Manager installation with Oracle Fusion Middleware 11g Standard Edition
One:
Report Manager is supported on Oracle Linux 6.5, 6.6, 6.7, 6.8 64-bit operating systems only.
- 300 GB hard drive minimum
- 64-bit JVK/JDK
- JDK version 1.6 (update 2) or higher
- 8 GB RAM for 64-bit JVM in large, high volume deployments
- 2 GB RAM for 32-bit JVM in small deployments
- 30 GB shared disk space for cluster deployments
- 20 GB non-shared, temporary disk space for document processing
- Plan to have 300 GB of disk space for storing HDR data, whether it is on the same system on which SDM is running or on a separate FTP or SFTP repository.
For more information about Oracle Communications Session Delivery Manager system requirements, see the Oracle Communications Session Delivery Manager Installation Guide for more information.
