Reset the Password for the Oracle Database User
Login to the server on which SDM is installed with the nncentral user.
ssh -Y nncentral@<OCSDM-Linux-server>
Change directory to the SDM bin directory.
cd /home/nncentral/AcmePacket/NNC<version>/bin
Execute the
shutdownnnc.sh script. By default, the shutdownnnc.sh script detects whether the existing installation is a standalone or clustered system and prompts you with the option to shut down the entire cluster if no flag options are provided.
You can script an option ahead of time by adding -local for single nodes and -cluster to shutdown an entire cluster../shutdownnnc.sh Shutdown back-end server Do you wish to shut down the entire cluster (Yes/No)? Yes
Go to the Oracle database bin home directory.
cd $ORACLE_HOME/bin
Specify the Oracle SID to ocsdmdw.
export ORACLE_SID=ocsdmdw
Connect to the Oracle database as the Oracle system administrator (sysdba).
./sqlplus / as sysdba SQL*Plus: Release 11.2.0.1.0 Production on Tue Mar 29 10:29:14 2017 Copyright (c) 1982, 2009, Oracle. All rights reserved. Connected to: Oracle Database 11g Release 11.2.0.1.0 - 64bit Production SQL>
Check the OCSREMDW user status.
SQL> select username, account_status from dba_users where username = 'OCSREMDW'; USERNAME ACCOUNT_STATUS ------------------------------ -------------------------------- OCSREMDW LOCKED
If the status is in the LOCKED status (the status before the password expires) then you must unlock the OCSREMDW user account before you reset the password. If there is a different status, such as OPEN, EXPIRED and LOCKED, or EXPIRED, skip this step and proceed to step 9.
SQL> alter user ocsremdw account unlock; User altered.
Reset the OCSREMDW password by entering the original password that was specified during original database installation.
SQL> alter user ocsremdw identified by <original password>; User altered.
Logout as the Oracle system administrator (sysdba).
SQL> exit; Disconnected from Oracle Database 11g Release 11.2.0.1.0 - 64bit Production
Connect to OCSDMDW database as the OCSREMDW user to ensure that the database is operational.
./sqlplus ocsremdw/<password>@ocsdmdw SQL*Plus: Release 11.2.0.1.0 Production on Tue Mar 29 10:43:17 2017 Copyright (c) 1982, 2009, Oracle. All rights reserved. Connected to: Oracle Database 11g Release 11.2.0.1.0 - 64bit Production SQL>
Logout as the OCSREMDW user.
Change to the SDM server bin directory.
Start the SDM server.
./startnnc.sh
Check the Reporting Service log to make sure that it was started successfully.
cd <OCSDM-INSTALL_DIRECTORY>/logs grep "service started" ReportingService.log 2016-02-09 16:44:37,988 INFO [com.acmepacket.ems.server.services.ReportingService] - Method: [startService] Thread: [ReportingService:25] Msg:[...service started]
- If you are running an SDM server cluster, repeat the previous steps for each cluster member node.
