Reports
The Report Manager provides a small set of predefined reports. Operational reports are the reports you run on aggregated HDR. To run a report, you must first configure collection groups. Consult the Report Manager Configuration chapter for more information.
If you enabled Single Sign On, clicking on Operational Reports in the Reports Manager slider will open BI Publisher in a new tab and sign you in to BI Publisher with the same account name used to sign in to SDM. If you did not enable Single Sign On, you will have to log in to BI Publisher manually.
If you are signed in as the Administrator, you will not see the Operational Report section of the Report Manager slider. To access Operational Reports, you must be signed in as a user who has Full privileges under section. See the Configuration chapter for details about adding users.
