Data Type Aggregation Behavior
Below is a table of data types, and the aggregation behavior for each type.
| Data Type | Aggregation Behavior |
| Dimension | Dimensions cannot be aggregated |
| Identifiers | Identifiers cannot be aggregated |
| State | The most recent state value |
| Boolean | The most recent boolean value |
| Count | The sum of the integer values |
| Range (i.e. 0-100) | The average of all values |
| Current value | The average of all values |
| Capacity | The average of all values |
| Index | The most recent index value |
| High water mark | The maximum value |
| Maximum rate | The maximum value |
| Low water mark | The minimum value |
| Minimum rate | The minimum value |
| Percentage | The average of all percentage values |
| Rate | The average of all rate values |
| Latency | The average of all latency values |
| Ratio | The average of all ratios |
| Speed | The average of all speeds |
| Temperature | The average of all temperatures |
