Apply User Group Privileges for Applications
  1. Expand the Security Manager slider and choose User Management > Groups.
  2. In the User Groups pane, select the group you want to modify from the User Groups table and click Edit.
  3. Select the Applications tab and click to expand the Applications folder.
  4. Select any folder or folder item row that are described in the table below that you want to modify and click the Privileges column to activate the drop-down list.
    Select the following privilege from the Privileges drop-down list:
    • Full—Enable GUI elements (such as tabs) to perform configuration operations.
    • View—View information only.
    • None—Disable configuration operations and make them disappear from the GUI.
    You must set the Execute Reports item privilege level to Full. See the table below for more information.
    Name Description
    Application folder Set privilege levels for all application operations.
    Report Manager folder Set privilege levels for all reporting operations accessible on the Report Manager slider.
    Execute Reports item You must set the privilege level for users belonging to a group to run reports full privileges so that collection reports can be configured.
    Administration folder Set all administration privileges for Oracle Communications Report Manager.
    Configure Retention Policy item Set privilege levels for a user group to create a retention policy for retaining Historical Data Recording (HDR) data over a period of time.
    Register BI Publisher item Set privilege levels for the Oracle Communications Report Manager to register with the Oracle Communications Session Delivery Manager before creating and running reports.
    Plugin Management folder Set administrative privileges for plugin management.
    Actions item Set plugin action privileges for a user assigned to the Plugin Management group to perform upload, install, uninstall, edit, delete, and recover actions.
  5. Click Apply.
