Pushing Data to the NNC Server
A device pushes historical data recording (HDR) data to the configured push receiver in standard CSV format.
Report Manager periodically monitors the push receiver folder, which is configured in Report Manager, for any new data. A push receiver is an FTP or SFTP destination server to which a device pushes records. The device creates a FTP an SFTP connection to the push receiver, or server, and the CSV files are pushed to the SDM server that is running the Report Manager application. If the server is a node of an SDM cluster, device data is delivered to each member in the cluster.
If a device is removed in SDM by deleting the network function (NF) to which it belongs, you can stop the sampling and pushing of HDR data from this device to SDM by logging into the device ACLI and using the request collection stop all command.
