Searching for Backups
You can search for route set backups based on name only, name and date and time, or on date and time.
- Expand the Route Manager slider, and click Backup/Restore.
- In the Route Set Backups tab, click Search.
In the
Backup Search dialog box, complete the following fields to configure your search criteria:
Name Description Name field The name of the route set backup. Starting at field and drop-down list The start date in YYYY-MM-DD format or click the calendar icon to select the date. Next, select the time of day from the drop-down list. Ending at field and drop-down list The end date in YYYY-MM-DD format or click the calendar icon to select the date. Next, select the time of day from the drop-down list. -
Click
Search.
The results display in the table.
- You can optionally click Show All to re-display all backups.
