Route Set
A route set contains a collection of the following route entries that can be imported from a CSV file or entered through the GUI.
| Name | Description |
| Order | The numerical value used as a mechanism for sorting the display of route records in the application or order the output of routes in the LRT that have the same pub-id. The order of display or output is lowest numerical value to highest. |
| Preference | The numerical value used as a mechanism for sorting the display of route records in the application or order the output of routes that have the same pub-id and order. The order of display or output is lowest numerical value to highest. |
| Destination Group | The group of public identifiers that have an object in common. That object stores information that can be used to select a subset of the route set for an operation, for example for global replacement. |
| Next Hop | The IP address, FQDN, session agent name, or session agent group name that can be used in the formula to generate the SED for a route record. |
| Trunk Group | The alphanumeric string that can be used in the formula to generate the SED for a route record. |
| Trunk Context | The alphanumeric string that can be used in the formula to generate the SED for a route record. |
| Routing Number (RN) | The telephone number or prefix that can be used in the formula to generate the SED for a route record. |
| Carrier identification code ($CIC) | The numeric value that can be used in the formula to generate the SED for a route record. |
| User 1 through User 5 | The alphanumeric value that has a user-specific definable meaning that can be used in the formula to generate the SED for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set. |
| SED Formula | The alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the SED for a route record. |
| Pub Id Formula | The alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the Pub Id for a route record. |
| NPA, NXX, Puser1, Puser2 | The alphanumeric value that has a user-specific definable meaning that can be used in the formula to generate the Pub-Id for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set. |
