Replacing Route Properties
You can replace a property for multiple routes based on search criteria.
- Expand the Route Manager slider, and click Route sets.
In the
Route sets tab, select the route and click
Lock.
The lock state toggles from unlocked, indicated by
, to locked, indicated by
. The name of the user who locked the route set is listed.
- With the locked route set selected, click Manage Routes.
- On the Route Set Edit tab, click Replace.
- In the Route Replace All dialog box, you can enter the search criteria such as pub-id, SED, and other property values. You can use the wildcard values asterisk (*) and question mark (?).
In the
Replace section, complete the following fields:
Name Description Field drop-down list Select from the following route properties that you want to replace: - NPA
- NXX
- Puser1
- Pub-id Formula
- SED
- SED Formula
- Destination Group
- Next Hop
- Order
- Preference
- Trunk Group
- Trunk Context
- Routing Number
- Carrier Identification Code
with value field The new value for the route property you selected in the Field parameter, which is the new value that replaces the old value for the field. - Click Replace.
- In the confirmation dialog box, click Yes to continue.
