Associating Route Sets with Devices
- Expand the Route Manager slider, and click Devices.
In the
Device Route Sets tab that appears by default, you can associate a route set with one or more device groups. Select a route set from the
Route Sets table
Name drop-down list
The Add button is disabled until a device group is selected. - Select one or more device groups and click Add.
- Optionally, you can select a route set from the Route Sets table Name drop-down list, and click Add to All to associate this route set with all device groups that are shown in the list.
- Use the previous steps to associate other route set(s) to available device group(s).
- Click OK when you are finished.
- In the success dialog box, click OK.
