Remove a Route Set Association from a Device Group
- Expand the Route Manager slider, and click Devices.
- In the Device Route Sets tab that appears by default, you can remove a route set association from one or more device groups.
Select a route set name from one or more device groups in the displayed list, and click
Remove.
The Remove button is disabled until a device is selected. - Optionally, you can select a route set name from any device group, and select Remove From All to remove this route set association from all other device groups that are displayed.
- Use the previous steps to remove associations of other route set(s) from device group(s).
- Click OK when you are finished.
- In the success dialog box, click OK.
