Adding Import Templates
- Expand the Route Manager slider, and click Import Templates.
- In the Import Templates tab, click Add.
- In the Choose Route Set dialog box, SBC is the default route set type. The DSC option is deprecated. Click OK.
In the
Add Import Templates dialog box, complete the following fields:
Name Description Name field The new import template name. Operation drop-down list Select a row number to map it to the corresponding Operation row in the CSV file from the drop-down list. pub id drop-down list Select a row number to map it to the corresponding Pub ID row in the CSV file from the drop-down list. Additional PubId Properties menu Click the arrow icon to expand the following Pub Id property entries that can be mapped to their corresponding CSV file column number: - NPA ($NPA), NXX ($NXX), PUser1 and PUser2 fields—Select the route entry that has the alphanumeric value that has a user-specific definable meaning that can be used in the formula to generate the Pub-Id for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set.
- Pub-id Formula—The alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the Pub Id for a route record.
If you enter a Pub-id Formula, the pub id field is disabled.
Session Establishment Data (SED) drop-down list Select the numerical entry for the next hop formula that generates the Session Establishment Data (SED). Order drop-down list Select the numerical entry that is used as a mechanism for sorting the display of route records in the application or order the output of routes in the LRT that have the same pub-id. The order of display or output is lowest numerical value to highest.
Preference drop-down list Select the numerical entry that is used as a mechanism for sorting the display of route records in the application or order the output of routes that have the same pub-id and order. The order of display or output is lowest numerical value to highest.
Destination Group($DESTGROUP) drop-down list Select the numerical entry that is used as the group of public identifiers that have an object in common. That object stores information that can be used to select a subset of the route set for an operation, for example for global replacement.
Additional SED Properties menu Click the arrow icon to expand the following SED property entries that can be mapped to their corresponding CSV file column number:- Imported SED formula—Select the numerical entry for the alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the SED for a route record.
- Next Hop ($NEXTHOP)—Select the numerical entry for the IP address, FQDN, session agent name, or session agent group name that can be used in the formula to generate the SED for a route record.
- Trunk Group ($TRUNKGROUP)—Select the numerical entry for the alphanumeric string that can be used in the formula to generate the SED for a route record.
- Trunk Context ($TRUNKCONTEXT)—Select the numerical entry for the alphanumeric string that can be used in the formula to generate the SED for a route record.
- Routing Number ($RN)—Select the numerical entry for the telephone number or prefix that can be used in the formula to generate the SED for a route record.
- Carrier Identification Code ($CIC)—Select the numerical entry for the numeric value used in the formula to generate the SED for a route record.
- User 1 through User 5 —Select the numerical entry for the alphanumeric value with a user-specific definable meaning that can be used in the formula to generate the SED for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set.
- SED Formula—The numerical entry for the alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the SED for a route record.
- Click OK.
