Rolling Back an Update
If the update failed and you selected the Roll back all successfully updated devices or Skip the failed device update and continue policy when adding an update task, you can rollback the update task and remove the locks on the associated device group.
You must own the lock on the route set to rollback for the device group.Note:
If you do not rollback an update task that fails, an error message displays similar to the example below when you attempt to perform another update task on device group(s) associated with the previous update task.
