Copying Import Templates
- Expand the Route Manager slider, and click Import Templates.
- In the Import Templates tab, select the row of the import template that you want to copy from the table and click Copy.
- In the Copy Import Template dialog box, enter a name for the template that you are creating and edit or add parameter entries that appear in this dialog box. See the Import Route Sets section for more information about these parameters.
- Click OK when you are finished creating the new import template.
