ipsec > security-association > manual
The manual subelement is where you manually configure a security association on the Oracle Communications Session Border Controller.
Parameters
- name
 - Enter the name for this security policy
 - spi
 - Set the security parameter index
- Default: 256
 - Values: Min: 256 | Max: 2302
 - network-interface
 - Enter the network interface and VLAN where this security association applies in the form of: interface_name:VLAN
 - local-ip-address
 - Enter the local IP address to match for traffic selectors for this SA
 - remote-ip-addr
 - Enter the remote IP address to match for traffic selectors for this SA
 - local-port
 - Enter the local port to match for traffic selectors for this SA
 - remote-port
 - Enter the remote port to match for traffic selectors for this SA
- Default: 0
 - Values: Min: 0 (disabled) | Max: 65535
 - trans-protocol
 - Select the transport protocol to match for traffic selectors for this SA
- Default: ALL
 - Values: UDP | TCP | ALL | ICMP
 - ipsec-protocol
 - Select the IPsec protocol used for this SA
- Default: esp
 - Values: esp | ah
 - direction
 - Set the direction of traffic this security association can apply to
- Default: both
 - Values: in | out | both
 - ipsec-mode
 - Select the IPsec mode of this SA
- Default: transport
 - Values: tunnel | transport
 - auth-algo
 - Select the IPsec authentication algorithm for this SA
- Default: null
 - Values: hmac-md5 | hmac-sha-1 | null
 - enrc-algo
 - Enter the IPsec encryption algorithm for this SA
- Default: null
 - Values: des | 3des | aes-128-cbc | aes-256-cbc | aes-128-ctr | aes-256-ctr | null
 - auth-key
 - Enter the authentication key for the previously chosen authentication algorithm for this SA
 - encr-key
 - Enter the encryption key for the previously chosen encryption algorithm for this SA
 - aes-ctr-nonce
 - Enter the AES nounce. This only applies if aes-128-ctr or aes-256-ctr are chosen as your encryption algorithm.
- Default: 0
 - tunnel-mode
 - Enter the tunnel-mode subelement
Path
security-association is a subelement under the ipsec element. The full path from the topmost ACLI prompt is:configure-terminal > security > ipsec > security-association
