system-config > collect > group-settings
The group-settings subelement allows you to configure and modify collection parameters for specific groups.
Parameters
- group-name
- Enter the name of the object the configuration parameters are for. There can only be one object per group.
- Values:
- system
- interface
- session-agent
- session-realm
- voltage
- fan
- temperature
- sip-sessions
- sip-ACL-oper
- sip-ACL-status
- sip-client
- sip-server
- sip-policy
- sip-errors
- sip-status
- sip-invites
- enum-stats
- h323-stats
- network-util
- space
- registration-realm
- tscf-stats
- Values:
- sample-interval
- Enter the group data collection sampling interval, in minutes
- Default: 0
- Values: Min: 0 / Max: 120
- start-time
- Enter the date and time to start group data collection. Enter in the form of: yyyy-mm-dd-hh:mm:ss (y=year; m=month; d=day; h=hour; m=minute; s=second)
- end-time
- Enter the date and time to stop group data collection. Enter in the form of: yyyy-mm-dd-hh:mm:ss (y=year; m=month; d=day; h=hour; m=minute; s=second)
- boot-state
- Enable or disable data collection for this group.
- Default: disabled
- Values: enabled | disabled
Path
group-settings is a subelement of the configure terminal > system > system-config > collect > subelement. The full path from the topmost ACLI prompt is: configure terminal > system > system-config > collect > group-settings
