authentication
The authentication configuration element is used for configuring an authentication profile.
Parameters
- source-port
- Enter the port number on the
Oracle Communications Session Border Controller to send messages to the RADIUS server
- Default: 1812
- Values: 1645 | 1812
- type
- Enter the type of user authentication
- Default: local
- Values: local | radius| tacacs
- protocol
- Select the protocol type to use with your RADIUS server(s)
- Default: pap
- Values: pap | chap | mschapv2 | ascii
- tacacs-authorization
- Enable or disable command-based authorization of admin users for TACACS.
- Default: enabled
- Values: enabled | disabled
- tacacs-accounting
- Enable or disable accounting of admin ACLI operations.
- Default: enabled
- server-assigned-privilege
- Enables a proprietary TACACS+ variant that, after successful user authentication, adds an additional TACACS+ request/reply exchange.
- Default: disabled
- allow-local-authorization
- Enable this parameter if you want the
Oracle Communications Session Border Controller to authorize users to enter Super (administrative) mode locally even when your RADIUS server does not return the ACME_USER_CLASS VSA or the Cisco-AVPair VSA.
- Default: disabled
- login-as-admin
- Enable this parameter if you want users to be logged automatically in Superuser (administrative) mode.
- Default: disabled
- management-strategy
- Enter the management strategy used to distribute authentication requests.
- Default: hunt
- Values: round-robin | hunt
- ike-radius-params-name
- Enter the auth-params instance to be assigned to this element.
- Default: None
- Values: Name of an existing auth-params configuration element
- management-servers
- Enter a list of servers used for management requests
- radius-servers
- Enter the radius-servers subelement
- tacacs-server
- Enter the tacacs-servers subelement
Path
authentication is an element under the security path. The full path from the topmost prompt is:
