network-parameters
The network-parameters element enables and configures the TCP keepalive feature used for keeping H.323 connections open. This is also used for global SCTP configuration.
Parameters
- tcp-keepalive-count
- Enter the number of outstanding keepalives before connection is torn down
- Default: 8
- Values: Min: 0 | Max: 4294967295
- tcp-keepalive-idle-timer
- Enter the idle time in seconds before triggering keepalive processing. If you have upgraded the release you are running and a value outside of the acceptable range was configured in an earlier release, the default value is used and a log message is generated.
- Default: 7200
- Values: Min: 30 | Max: 7200
- tcp-keepalive-mode
- Enter the TCP keepalive mode
- Default: 0
- Values:
- 0—The sequence number is sent un-incremented
- 1—The sequence number is sent incremented
- 2—No packets are sent
- tcp-keepinit-timer
- Enter the TCP connection timeout period if a TCP connection cannot be established. If you have upgraded the release you are running and a value outside of the acceptable range was configured in an earlier release, the default value is used and a log message is generated.
- Default: 75
- Values: 0-999999999
- tcp-keepalive-interval-timer
- Enter the TCP retransmission time if a TCP connection probe has been idle for some amount of time
- Default: 75
- Values: Min: 15 / Max: 75
- sctp-send-mode
- Leave this parameter set to its default (unordered) so data delivery can occur without regard to stream sequence numbering. If data delivery must follow stream sequence number, change this parameter to ordered.
- Default: unordered
- Values: ordered | unordered
- sctp-rto-initial
- Sets the initial value of the SCTP retransmit timeout (RTO).
- Default: 3000 msec (value recommended by RFC 4960)
- Values: 0-4294967295
- sctp-rto-max
- Sets the maximum value of the SCTP retransmit timeout (RTO).
- Default: 60000 msec (value recommended by RFC 4960)
- sctp-rto-min
- Default: 1000 msec (value recommended by RFC 4960)
- sctp-hb-interval
- Sets the initial value of the SCTP Heartbeat Interval timer.
- Default: 30000 msec (value recommended by RFC 4960)
- sctp-max-burst
- Sets the maximum number of DATA chunks contained in a single SCTP packet.
- Default: 4 DATA chunks (value recommended by RFC 4960)
- sctp-sack-timeout
- Sets the initial value of the SACK (Selective Acknowledgement) Delay timer.
- Default: 200 msec (value recommended by RFC 4960)
- Values: 0-500
- sctp-assoc-max-retrans
- Specifies the maximum number of consecutive unacknowledged retransmissions to a specific SCTP endpoint. Should this value be exceeded, the endpoint is considered to be unreachable, and the SCTP association is placed in the CLOSED state.
- Default: 10 retries (value recommended by RFC 4960)
- sctp-path-max-retrans
- Specifies the maximum number of RTO expirations/unacknowledged HEARTBEATS to a specific SCTP transport address. Should this value be exceeded, the endpoint is considered to be inactive, and an alternate transport address, if available, will be used for subsequent transmissions.
- Default: 5
- options
- Enter any optional features or parameters
Path
network-parameters is an element under the system path. The full path from the topmost ACLI prompt is:
This is a single instance configuration subelement.
