system-config
The system-config element establishes general system information and settings.
Parameters
- hostname
- Enter the main hostname that identifies the Oracle Communications Session Border Controller. Entries must follow either the Hostname (or FQDN) Format or the IP Address Format.
- description
- Describe the Oracle Communications Session Border Controller. Entries must follow the Text Format
- location
- Enter the physical location of the Oracle Communications Session Border Controller used for informational purposes. Entries must follow the Text Format.
- mib-system-contact
- Enter the contact information for this Oracle Communications Session Border Controller for SNMP purposes. This field value is the value reported for MIB-II when an SNMP GET is issued by the NMS. Entries must follow the Text Format.
- mib-system-name
- Enter the identification of the Oracle Communications Session Border Controller for SNMP purposes. This value has no relation to the system-config > hostname field. By convention, this is the node’s FQDN. If this field remains empty, the Oracle Communications Session Border Controller name that appears in SNMP communications will be the target name configured in the boot parameters and nothing else.
- mib-system-location
- Enter the physical location of the Oracle Communications Session Border Controller for SNMP purposes. This parameter has no direct relation to the location field identified above. Entries must follow the Text Format
- snmp-enabled
- Enable or disable SNMP is enabled. If SNMP is enabled, then the system will initiate the SNMP agent. If SNMP is disabled, then the SNMP agent will not be initiated, and the trap-receiver and snmp-community elements will not be functional.
- Default: enabled
- Values: enabled | disabled
- enable-snmp-auth-traps
- Enable or disable the SNMP authentication traps
- Default: disabled
- enable-snmp-syslog-notify
- Enable or disable sending syslog notifications to an NMS via SNMP; determines whether SNMP traps are sent when a
Oracle Communications Session Border Controller generates a syslog message
- Default: disabled
- enable-snmp-monitor-traps
- Determine whether traps are sent out in ap-smgmt.mib trap. (See MIB Reference Guide for more information)
- Default: disabled
- enable-env-monitor-traps
- Determine whether the environmental monitoring MIB is sent from the
Oracle Communications Session Border Controller. This trap will be sent any time there is a change in state in fan speed, temperature, voltage (SD 2 only), power supply (SD 1 for rev 1.32 or higher, SD 2 w/QoS for rev 1.32 or higher, SD II no QoS for rev 1.3 or higher), phy-card insertion, or I2C bus status. If this parameter is set to enabled, fan speed, temperature, and power supply notifications are not sent out in other traps.
- Default: disabled
- snmp-syslog-his-table-length
- Enter the maximum entries that the SNMP Syslog message table contains. The system will delete the oldest table entry and add the newest entry in the vacated space when the table reaches maximum capacity.
- Default: 1
- Values: Min: 1 / Max: 500
- snmp-syslog-level
- Set the log severity levels that send syslog notifications to an NMS via SNMP if snmp-syslog-notify is set to enabled. If the severity of the log being written is of equal or greater severity than the snmp-syslog-level value, the log will be written to the SNMP syslog history table. If the severity of the log being written is of equal or greater severity than the snmp-syslog-level field value and if enabled-snmp-syslog-notify field is set to enabled, the system will send the syslog message to an NMS via SNMP. If the severity of the log being written is of lesser severity than the snmp-syslog-level value, then the log will not be written to the SNMP syslog history table and it will be disregarded.
- Default: warning
- Values:
- emergency
- critical
- major
- minor
- warning
- notice
- info
- trace
- debug
- detail
- syslog-servers
- Access the syslog-servers subelement
- system-log-level
- Set the system-wide log severity levels write to the system log
- Default: warning
- Values:
- emergency
- critical
- major
- minor
- warning
- notice
- info
- trace
- debug
- detail
- process-log-level
- Set the default log level that processes running on the
Oracle Communications Session Border Controller start
- Default: notice
- Values:
- emergency
- critical
- major
- minor
- warning
- notice
- info
- trace
- debug
- detail
- process-log-ip-address
- Enter the IP address of server where process log files are stored. Entries must follow the IP Address Format. The default value of 0.0.0.0 causes log messages to be written to the local log file.
- Default: 0.0.0.0
- process-log-port
- Enter the port number associated with server IP address where process log files are stored. The default value of 0 writes log messages to the local log file.
- Default: 0
- Values: Min: 0; 1025 / Max: 65535
- collect
- Accesses the collect subelement
- call-trace
- Enable or disable protocol message tracing for sipmsg.log for SIP
- Default: disabled
- internal-trace
- Enable or disable internal ACP message tracing for all processes
- Default: disabled
- log-filter
- Set to logs or all to send the logs to the log server
- Default: all
- Values:
- none
- traces
- traces-fork
- logs
- log-fork
- all
- all-fork
- default-gateway
- Enter the IP address of the gateway to use when IP traffic sent by the
Oracle Communications Session Border Controller is destined for a network other than one of the LANs on which the 10/100 Ethernet interfaces could be. Entries must follow the IP Address Format. A value of 0.0.0.0 indicates there is no default gateway.
- Default: 0.0.0.0
- restart
Oracle Communications Session Border Controller rebooting when a task is suspended. When set to enabled, this field causes the
Oracle Communications Session Border Controller to reboot automatically when it detects a suspended task. When this field is set to disabled and a task is suspended, the
Oracle Communications Session Border Controller does not reboot.
- Default: enabled
- exceptions
- Select system tasks that have no impact on system health or cause the system to restart. This field contains the name(s) of the task(s) surrounded by quotation marks. If there are multiple entries, they should be listed within quotation marks, with each entry separated by a <Space>.
- telnet-timeout
- Enter the time in seconds the
Oracle Communications Session Border Controller waits when there is no Telnet activity before an administrative telnet session, or SSH connection, is terminated. A value of 0 disables this functionality, meaning no time-out is being enforced.
- Default: 0
- Values: Min: 0 / Max: 65535
- console-timeout
Oracle Communications Session Border Controller waits when there is no activity on an ACLI administrative session before it terminates the session. The ACLI returns to the User Access Verification login sequence after it terminates a console session. A value of 0 disables this functionality.
- Default: 0
- remote-control
- Enable or disable listening for remote ACP config and control messages before disconnecting
- Default: enabled
- cli-audit-trail
- Enable or disable the ACLI command audit trail. The cli-audit-trail outputs to cli.audit.log.
- Default: enabled
- link-redundancy-state
- Enable or disable the link redundancy
- Default: disabled
- source-routing
- This parameter / feature has been deprecated.
- cli-more
- Enable this parameter to have the ACLI “more” paging feature working consistently across console or SSH sessions with the
Oracle Communications Session Border Controller. When this parameter is disabled, you must continue to set this feature on a per session basis.
- Default: disabled
- terminal-height
- Set the
Oracle Communications Session Border Controller terminal height when the more prompt option is enable
- Default: 24
- Values: Minimum: 5 / Maximum: 1000
- debug-timeout
- Enter the time, in seconds, you want to the
Oracle Communications Session Border Controller to timeout log levels for system processes set to debug using the ACLI notify and debug commands. A value of 0 disables this parameter.
- Default: 0
- trap-event-lifetime
- Set this parameter to the number of days you want to keep the information in the alarm synchronization table; 0 turns alarm synchronization off
- Default: 0
- Values: Min: 0 / Max: 7
- ids-syslog-facility
- Enter a syslog facility, as entered in the syslog-config configuration element, facility parameter to send IDS-type syslog messages to that syslog server. The default value of -1 disables selective message transfer.
- Default: -1
- default-v6-gateway
- Set the IPv6 default gateway for this Oracle Communications Session Border Controller. This is the IPv6 egress gateway for traffic without an explicit destination. The application of your Oracle Communications Session Border Controller determines the configuration of this parameter.
- ipv6-signaling-mtu
- This sets the system-wide, default IPv6 MTU size.
- Default: 1500
- Values: 1280-4096
- ipv4-signaling-mtu
- This sets the system-wide, default IPv4 MTU size.
- Default: 1500
- Values: 576-4096
- alarm-threshold
- Accesses the alarm-threshold subelement.
- cleanup-time-of-day
- Enter the local time the
Oracle Communications Session Border Controller begins inspecting directories to perform the clean up process.
directory-cleanup—Enters the directory-cleanup subelement.
- snmp-engine-id-suffix
- Sets a unique suffix for the SNMPEngineID. This value is entered as a string.
- snmp-agent-mode
- Determines which version of SNMP is supported on this system.
- Default: v1v2
- Values: v1v2 | secure-trap
- options
- Enter any customer-specific features and/or parameters for this global system configuration. This parameter is optional.
Path
system-config is an element under the system path. The full path from the topmost ACLI prompt is:
Under the system-config element, options are not RTC supported. This is a single instance configuration element.First appearance: 1.0 / Most recent update: 6.3
