sip-interface
The sip-interface element allows you to configure a SIP interface for your Oracle Communications Session Border Controller.
Parameters
- state
- Enable or disable the SIP interface
- Default: enabled
- Values: enabled | disabled
- realm-id
- Enter the name of the realm to which the SIP interface applies
- description
- Provide a brief description of the sip-interface configuration element
- sip-ports
- Access the sip-ports subelement
- carriers
- Enter a list of carriers related to the sip-config. Entries in this field must follow the Carrier Format.
- trans-expire
- Set the transaction expiration timer in seconds
- Default: 0
- Values: Min: 0 | Max: 999999999
- invite-expire
- Set the INVITE transaction expiration timer in seconds
- Default: 0
- max-redirect-contacts
- Enter the maximum number of contact and route attempts in case of a redirect
- Default: 0
- Values: Min: 0 | Max: 10
- proxy-mode
- Set the default SIP request proxy mode
- Values:
- proxy—Forward all SIP requests to other session agents
- redirect—Send a SIP 3xx redirect response with contacts (found in the local policy) to the previous hop
- record-route—Forward requests with Record-Route (for stateless and transaction and operation modes only)
- Values:
- redirect-action
- Set handling of Redirect (3xx) response messages from a session agent.
- Default: Recurse
- Values:
- Proxy—Send the response back to the previous hop
- Recurse—Recurse on the contacts in the response
- Recurse-305-only—recurse on the contacts in the 305 response
- contact-mode
- Select the contact header routing mode
- Default: none
- Values:
- none
- maddr
- strict
- loose
- nat-traversal
- Select the type of HNT functionality for SIP
- Default: none
- Values:
- none—NAT Traversal is disabled
- always—Performs HNT when SIP-Via and transport addresses do not match
- rport—Performs HNT when Via rport parameter is present and SIP-Via and transport addresses do not match
- nat-interval
- Enter the expiration time in seconds for the system’s cached registration entry for an endpoint doing HNT
- Default: 30
- Values: Min: 1 | Max: 999999999
- tcp-nat-interval
- Enter the TCP NAT traversal registration interval in seconds
- Default: 90
- Values: Min: 0 / Max: 999999999
- registration-caching
- Enable or disable registration cache used for all UAs rather than those behind NATs
- Default: disabled
- min-reg-expire
- Enter the minimum registration expiration time in seconds for HNT registration caching
- Default: 300
- registration-interval
Oracle Communications Session Border Controller’s cached registration entry for an endpoint (non-HNT)
- Default: 3600
- route-to-registrar
- Indicate whether or not the SD should forward a request addressed to the registrar to the SIP registrar as opposed to sending the request to the registered contact in the registration cache
- Default: disabled
- secured-network
- Enable or disable sending messages on unsecured transport
- Default: disabled
- teluri-scheme
- Enable or disable the conversion of SIP URIs to Tel URIs
- Default: disabled
- uri-fqdn-domain
- Change the host part of the URIs to the FQDN value set here. This applies to the Request-URI, From header, and To header in non-dialog requests sent from the SIP interface.
- trust-mode
- Select the trust mode for this SIP interface
- Default: all
- Values:
- all—Trust all previous and next hops except untrusted session agents
- agents-only—Trust only trusted session agents
- realm-prefix—Trust only trusted session agents or address matching realm prefix
- registered—Trust only trusted session agents or registered endpoints
- None—Trust nothing
- max-nat-interval
- Enter the amount of time in seconds that testing should not exceed for adaptive HNT. The system will keep the expires interval at this value.
- Default: 3600
- nat-int-increment
- Enter the amount of time in seconds to use as the increment in value in the SIP expires header for adaptive HNT
- Default: 10
- nat-test-increment
- Enter the amount of time in seconds that will be added to the test timer for adaptive HNT
- Default: 30
- sip-dynamic-hnt
- Enable or disable adaptive HNT
- Default: disabled
- stop-recurse
- Enter a list of returned response codes that this SIP interface will watch for in order to stop recursion on the target’s or contact’s messages
- port-map-start
- Set the starting port for the range of SIP ports available for SIP port mapping. A value of 0 disables SIP port mapping.
- Default: 0
- Values: Min: 1025 | Max: 65535
- port-map-end
- Set the ending port for the range of SIP ports available for SIP port mapping. A value of 0 disables SIP port mapping. This value must be larger than the port-map-start parameter’s value.
- Default: 0
- in-manipulationid
- Enter the name of the SIP header manipulations configuration to apply to the traffic entering the Oracle Communications Session Border Controller via this SIP interface
- out-manipulationid
- Enter the name of the SIP header manipulations configuration to apply to the traffic exiting the Oracle Communications Session Border Controller via this SIP interface
- manipulation-pattern
- Number of seconds after de-registration to kill TCP connection
- manipulation-string
- Enter the string used in header manipulation rules for this sip-interface.
- sip-ims-feature
- Enable or disable IMS functionality on this SIP interface
- Default: disabled
- subscribe-reg-event
- Enables the
Oracle Communications Session Border Controller to generate SIP registration events.
- Default: disabled
- operator-identifier
- Set the operator identifier value to be inserted into a P-Charging-Vector header. The direction of the call determines whether this value is inserted into the orig-ioi or the term-ioi parameter in the P-Charging-Vector header. This string value MUST begin with an alpha character.
- anonymous-priority
- Set the policy priority parameter for this SIP interface. It is used to facilitate emergency sessions from unregistered endpoints. This value is compared against a policy priority parameter in a local policy configuration element.
- Default: none
- Values:
- none
- normal
- non-urgent
- urgent
- emergency
- max-incoming-conns
- Enter the maximum number of TCP/TLS connections for this sip interface
- Default: 0
- Values: Min: 0 / Max: 20000; setting a value of 0 disables this parameter
- per-scr-ip-max-incoming-conns
- Enter the maximum number of TCP/TLS connections per peer IP address
- Default: 0
- Values: Min: 0 / Max: 20000; setting a value of 0 disables this parameter.
- inactive-conn-timeout
- Enter the timeout, measured in seconds for idle TCP/TLS connections
- Default: 0
- Values: Min: 0 / Max: 999999999; setting a value of 0 disables the timer.
- untrusted-conn-timeout
- Enter the timeout time, in seconds, for untrusted endpoints on TCP/TLS connections
- Default: 0
- Values: Min: 0 (disabled) | Max: 999999999
- network-id
- Set the value that will be inserted into the P-Visited-Network-ID header
- ext-policy-server
- Enter the name of external policy server used as the CLF for this SIP interface
- default-location-string
- Set a default location string to insert into P-Access-Network-Info header when the CLF does not return this value
- charging-vector-mode
- Set the state of P-Charging-Vector header handling
- Default pass
- Values:
- none—Pass the P-Charging-Vector header received in an incoming SIP message untouched as the message is forwarded out of the Oracle Communications Session Border Controller, not extracting RADIUS information
- pass—Pass the P-Charging-Vector header received in an incoming SIP message untouched as the message is forwarded out of the Oracle Communications Session Border Controller, extracting RADIUS information
- delete—Delete the P-Charging-Vector header received in an incoming SIP message before it is forwarded out of the Oracle Communications Session Border Controller
- insert—Inserts the P-Charging-Vector header in an incoming SIP message that does not contain the P-Charging-Vector header. If the incoming message contains the P-Charging-Vector header, the Oracle Communications Session Border Controller will overwrite the P-Charging-Vector header with its values.
- delete-and-respond—Removes the P-Charging-Vector from incoming requests for a session and store it. Then the
Oracle Communications Session Border Controller inserts it into outbound responses related to that session in a P-Charging-Vector header.
Note that the default setting for the charging-vector-mode is pass for new SIP interface configurations. If you are upgrading and there are pre-existing SIP interfaces in your (upgraded) configuration, the default becomes none.
- charging-function-address-mode
- Set the state of P-Charging-Function-Address header handling
- Default: pass
- Values:
- none—Pass the P-Charging-Function-Address header received in an incoming SIP message untouched as the message is forwarded out of the Oracle Communications Session Border Controller, not extracting RADIUS information
- pass—Pass the P-Charging-Function-Address header received in an incoming SIP message untouched as the message is forwarded out of the Oracle Communications Session Border Controller, extracting RADIUS information
- delete—Delete the P-Charging-Function-Address header received in an incoming SIP message before it is forwarded out of the Oracle Communications Session Border Controller
- insert—Inserts the P-Charging-Function-Address header in an incoming SIP message that does not contain the P-Charging-Function-Address header. If the incoming message contains the P-Charging-Function-Address header, the Oracle Communications Session Border Controller will prepend its configured values to the header.
- insert-reg-cache—To be configured on the SIP interface facing the UE, configures the Oracle Communications Session Border Controller to replace the PCFA with the most recently cached values rather than the ccf-address you set to be static in your configuration. The cached values come from one of the following that the Oracle Communications Session Border Controller has received most recently: request, response, registration, or local configuration.
- delete-and-respond—To be configured on the SIP interface facing the S-CPCF, configures the
Oracle Communications Session Border Controller to strip out the latest cached PCFA.
Note that the default setting for the charging-function-address-mode is pass for new SIP interface configurations. If you are upgrading and there are pre-existing SIP interfaces in your (upgraded) configuration, the default becomes none.
- ccf-address
- Set the CCF address value that will be inserted into the P-Charging-Function-Address header
- ecf-address
- Set the ECF address value that will be inserted into the P-Charging-Function-Address header
- term-tgrp-mode
- Select the mode for routing for terminating trunk group URIs
- Default: none
- Values:
- none—Disable routing based on trunk groups
- iptel—Use trunk group URI routing based on the IPTEL formats
- egress-uri—Use trunk group URI routing based on the egress URI format
- implicit-service-route
- Enable or disable the implicit service route behavior
- Default: disabled
- Values:
- enabled
- disabled
- strict
- rfc2833-payload
- Enter the payload type used by the SIP interface in preferred rfc2833-mode
- Default: 101
- Values: Min: 96 | Max: 127
- rfc2833-mode
- Choose whether the SIP interface will behave exactly the same way as before and the 2833or UII negotiation will be transparent to the
Oracle Communications Session Border Controller, transparent, or whether the sip-interface prefers to use 2833 for DTMF transfer and would signal that in its SDP, preferred. However the final decision depends on the remote endpoint.
- Default: transparent
- Values: transparent | preferred | dual
- constraint-name
- Enter the name of the constraint being applied to this interface
- response-map
- Enter the name of the response map being applied to this interface
- local-response-map
- Enter the name of the local response map being applied to this interface
- sec-agree-feature
- Determines if sec-agree feature is enabled.
- Default disabled
- Values enabled | disabled
- sec-agree-pref
- Determines the security protocol preferences used with Sec-agree support
- Default: ipsec3gpp
- Values:
- ipsec3gpp — support only IMS-AKA protocol
- tls — support only TLS protocol
- ipsec3gpp-tls — support both IMS-AKA and TLS, preferred protocol is IMS-AKA
- tls-ipsec3gpp — support both TLS and IMS-AKA, preferred protocol is TLS
- ims-aka-feature
- Enable or disable IMS-AKA use for a SIP interface
- Default disabled
- enforcement-profile
- Enter the name of the enforcement profile associated with this SIP interface
- route-unauthorized-calls
- Enter the name of the SA or SAG you want to route unauthorized calls
- tcp-keepalive
- Enable or disable standard keepalive probes to determine whether or not connectivity with a remote peer is lost.
- Default: none
- Values: none | enabled | disabled
- add-sdp-invite
- Enable or disable this SIP interface inserting an SDP into either an INVITE or a REINVITE
- Default: disabled
- Values:
- disabled—Do not insert an SDP
- invite—Insert an SDP in the invite
- reinvite—Insert an SDP in the reinvite
- add-sdp-profile
- Enter a list of one or more media profile configurations you want to use when the Oracle Communications Session Border Controller inserts SDP into incoming INVITEs that have no SDP. The media profile contains media information the Oracle Communications Session Border Controller inserts in outgoing INVITE.
- add-sdp-in-msg
- Identifies the messages in which to insert SDP offers or answers. The only allowable value is
18xresp. The default is null (no value).
- Default: null
- Values:
- 18xresp—For an offerless INVITE that needs preconditions, causes the Oracle Communications Session Border Controller to insert the SDP, as configured in the media profile names listed in add-sdp-profiles-in-msg, in the 18x (183) response towards the UE.
- add-sdp-profile-in-msg
- Identifies a list of media profiles that contain, based on the codec, the SDP to insert in the 18x response when add-sdp-in-msg is configured.
- sip-profile
- Enter the name of the sip-profile to apply to this interface.
- sip-isup-profile
- Enter the name of the sip-isup-profile to apply to this interface.
- tcp-conn-dereg
- Number of seconds after de-registration to kill TCP connection.
- Default 0 (disabled)
- tunnel-name
- Tunnel traffic for load balancer. Traffic sent to/from this interface will be encapsulated in an RFC 2003 compliant tunnel to/from the load balancer usign the associated network-interface's tunnel name.
- register-keep-alive
- Sets the use of RFC 5626 CRLF Keepalives on this sip interface.
- Default: none
- Values:
- none—disables this feature
- always— Keepalive always added to SIP-Via
- bnat— Keepalive added to SIP-Via when SIP-via and transport addresses do not match (indicates endpoint is behind a NAT)
- kpml-interworking
- Enables or disables the KPML to RFC2833 interwokring feature.
- Default: disabled
- msrp-delay-egress-bye
- Delay egress BYE message.
- Default: disabled
- send-380-response
- The phrase entered in this parameter is inserted into the <reason> element in the <alternative-service> element in the XML body in the 380 response returned to an endpoint when the call cannot be completed. This is in compliance with GSMA's Voice over LTE specification (IR. 92).
- pcscf-restoration
- Configure a reason phrase, enclosed in quotes, that will be included in the P-CSCF restoration response, the reason field of a 504 response sent back to the UE.
- session-timer-profile
- A session-timer-profile name is configured here to apply that session timer profile to this SIP interface.
- session-recording-server
- Name of the session-recording-server or the session-recording-group object in the realm associated with the session reporting client. Valid values are alpha-numeric characters. session recording groups are indicated by prepending the groupname with SRG:
- session-recording-required
- Determines whether calls are accepted by the SBC if recording is not available.
- Default: disabled
- Values:
- enabled—Restricts call sessions from being initiated when a recording server is not available.
- disabled—Allows call sessions to initiate even if the recording server is not available.
- p-early-media-header
- Used to enable P-Early-Media SIP header support.
- Default: Disabled
- Values:
- disabled—(the default value) disables support
- add—enables support and allows the SBC/P-CSCF to add the P-Early-Media header to SIP messages.
- modify—enables support and allows the SBC/P-CSCF to modify or strip the P-Early-Media header in SIP messages.
- p-early-media-direction
- Used to specify the supported directionalities. for P-Early-Media header support.
- sendrecv—send and accept early media
- sendonly—send early media
- recvonly—receive early media
- inactive—reject/cancel early media
- options
- Enter optional features and/or parameters
- diversion-info-mapping-mode
- Configure this parameter to specify how the Diversion and Header-Info headers map to and work with each other on the interface.
- Default none
- Values:
- none—no conversion applied
- div2hist—any Diversion headers in the initial INVITEs going out of this SIP interface will be converted to Historing-info headers before sending
- force—behavior is the same as div2hist when a Diversaion header is present in the incoming INVITE if there are no Diversion headers, a History-Info header for the current URI is added in the outgoing INVITE
- hist2div—any History-Info headers in the initial INVITEs going out of this sip interface will be converted to Diversion headers before sending
- asymmetric-preconditions
- Identifies whether to enable preconditions interworking on the interface. Allowable values are
enabled and
disabled. The default is
disabled. You cannot enable asymmetric preconditions unless you have first set the value of
sip-interface > options to
100rel-interworking.
- Default: disabled
- Values:
- enabled—Enables preconditions interworking on the interface.
- disabled—Disables preconditions interworking on the interface.
- asymmetric-preconditions-mode
- Identifies, when the value of
asymmetric-preconditions is
enabled, whether to send egress INVITEs immediately or to delay them until preconditions have been met. Allowable values are
send-with-delay and
send-with-nodelay.
- Default: send-with-nodelay
- Values:
- send-with-delay—Delays INVITEs on the egress interface until preconditions are met on the ingress interface.
- send-with-nodelay—Forwards INVITEs to the egress interface immediately, but holds the responses until preconditions are met on the ingress interface.
Path
sip-interface is an element under the session-router path. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
