5. Importing Reports to BI Publisher Server
To import reports to BI Publisher Server, do the following:
- Copy and extract the OFSLLReports.zip file to local area. Assume you have extracted to /home/oracle/app/OFSLLReports, then the zip file “oracle.xdrz” is extracted to /home/oracle/app/OFSLLReports
- Launch the Oracle Business Intelligence Publisher Application using http://hostname:port/xmlpserver
- Login with valid credentials.
- Following window is displayed. Click on ‘Catalog Folders’ on the left pane.
- Click on ‘Shared Folders’ option and then click ‘Upload’.
- The following window is displayed. Browse to the location where the oracle.xdrz file is saved. Click the 'Overwrite Existing File' check box if you are overwriting an existing directory.
- Click on ‘Upload’.
- Once the upload is completed, click any folder to see the list of reports under the directory. The following window is displayed.
