This manual is designed to help you quickly get acquainted with the Common Core - Core Entities and Services module of Oracle FLEXCUBE.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office clerk | Input functions for contracts | ||
| Back office managers/officers | Authorization functions | ||
| Product Managers | Product definition and authorization | ||
| End of day operators | Processing during end of day/ beginning of day | ||
| Financial Controller/Product Managers | Generation of reports |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
| Chapter | Description | ||
| Chapter 1 | Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Core Maintenances explains the maintenance of various basic details about your bank. | ||
| Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
![]() | Exit | ||
![]() | Add row | ||
![]() | Delete row | ||
![]() | Option List |
For further information on procedures discussed in the manual, refer to the Oracle FLEXCUBE manuals on:
