This manual is designed to help you quickly get acquainted with the Integration Gateway of Oracle Banking Payments.
It provides an overview to the module, and provides information on using the Integration Gateway module of Oracle Banking Payments.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| IT department members responsible for integration | Input functions for maintenance related to the gateway | ||
| IT managers | Authorization functions |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Gateway Functions - An Overview explains the features of this module. | ||
| Chapter 3 | Gateway Maintenances explains the core features of this module. | ||
| Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
![]() | Exit | ||
![]() | Add row | ||
![]() | Delete row | ||
![]() | Option List |
For further information on procedures discussed in the manual, refer to the Oracle Banking Payments manuals on:
