The Cross-border (SWIFT) Payments module (product processor) of Oracle Banking Payments is a standalone product processor. Payments module provides out of the box support for processing incoming and outgoing SWIFT Payments. This module helps you process funds transfer transactions between financial institutions based anywhere across the globe. Following fund transfers are supported:
The Cross-border product processor processes a SWIFT payment transaction initiated by an Operations user from the in-built user interface or by customers in the bank’s Customer Channels like Internet banking or Mobile banking. The payment instructions initiated from the bank Channels are received by Oracle Banking Payments through ReST or SOAP based interfaces.
Key Features of Cross Border Product Processor
This chapter contains details of the following maintenances specific to Cross-border payments:
Usage of this screen
You can specify currency correspondent account details in this screen. Currency correspondent Maintenance function is Host specific.
You can invoke the ‘Currency Correspondent Maintenance’ screen by typing ‘PMDCYCOR’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
You can specify the following fields:
Host Code
The system displays the Host Code of the selected branch of the logged in user.
Currency
Specify the currency. Alternatively, you can select the currency from the option list. The list displays all valid currencies maintained in the system.
Account Type
Select the account type. The list displays the following values:
Account Number
Specify the account number associated with the correspondent input in the Bank Code field in the specified currency
Alternatively, you can select the parent account number from the option list. The list displays all Nostro accounts for Account type OUR and valid normal accounts for account type THEIR. The account currency displayed in the list should be same as the currency specified. Accounts maintained per currency correspondent to be unique. Same account cannot be maintained across multiple BIC’s.
Account Name
The system displays the account name of the account number.
Primary Correspondent
Check this box if this correspondent is the primary currency correspondent. This option is applicable only for Account type ‘OUR’. There can be only one primary currency correspondent for the combination of Account type, Currency.
MT210 required?
Check this box to indicate if MT210 is required to be sent to the Currency Correspondent in the scenarios where it is auto-generated like generation of outgoing MT200/MT201. Only if this check box is checked, the system would generate the MT210 as per the existing behavior, else system would not generate MT210.
Max Claim Amount
Specifies the maximum amount that can be claimed by the correspondent in MT191 message.
Charge Claim GL
Specifies the GL code that is used to debit the charges as part of processing of the outgoing Bank transfer Transaction for the charge claim.
You can invoke “Currency Correspondent Summary” screen by typing ‘PMSCYCOR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can search using one or more of the following parameters:
Once you have specified the search parameters, click ‘Search’ button. The system displays the records that match the search criteria for the following
You can maintain the correspondent relationship between any two banks in a specific currency in the Global correspondent screen.
You can invoke the ‘Global correspondent Maintenance’ screen by typing ‘PMDGLCOR’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Host Code
Bank Code
Specify the BIC code of the bank for which you need to maintain a Correspondent. Alternatively, you can select the BIC code from the option list. The list displays all valid BIC codes maintained in the system.
Currency
Correspondent Bank
The system displays the name of the correspondent Bank based on the specified BIC code.
You can invoke “Global Correspondent Summary” screen by typing ‘PMSGLCOR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Once you have specified the search parameters, click ‘Search’ button. The system displays the records that match the search criteria.
You can invoke “Outgoing BIC Cutoff” screen by typing ‘PXDCYCOF’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button
You can specify the following details:
Host Code
Displays the Host Code of the selected branch of the logged in user.
BIC Code
Specify the BIC Code. Alternatively, you can select the BIC Code from the option list. The list displays all valid BIC Codes maintained in the system.
Currency Code
Specify the currency code. Alternatively, you can select the currency code from the option list.
The list displays all valid currency codes maintained in the system for the selected country.
Limit Amount
Specify the limit amount for the transaction amount.
Cutoff Hour
Specify the hours for the transaction cut-off time.
Cutoff Minute
Specify the minutes for the transaction cut-off time.
Settlement Days
Specify the number of days in advance of the current day on which the settlement is applicable that the payment request needs to be received or the transaction booked from screen.
You can invoke “Outgoing BIC Cutoff Summary” screen by typing 'PXSCYCOF' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke “Incoming BIC Cutoff” screen by typing ‘PXDINCOF’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button
Host Code
BIC Code
Currency Code
Limit Amount
Cutoff Hour
Cutoff Minute
Settlement Days
You can invoke “Incoming BIC Cutoff Summary” screen by typing 'PXSINCOF' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can maintain Sender Receiver Agreement in this screen.This is used for capturing Bi-lateral agreement for exchanging MT102/MT102+messages with a particular bank.
You can invoke “Sender Receiver Agreement” screen by typing ‘PXDSRAGM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the following details.
Host Code
Displays the Host code of the selected branch.
Counterparty Bank
Specify the Bank Code as the 1st 6 characters of a BIC code comprising 4 characters identifying the bank and the next 2 characters identifying the Country code. This can be maintained for a specific BIC.
Transaction Currency
Specify the transaction currency.
Bank Name
Specify the name of the bank.
SWIFT Message Type
Specify the SWIFT Messsage Type. You can select MT102 for Console or MT 103 for GPI transactions.
Transactions per message
Specifies the maximum number of transactions in one Multi-credit Customer Transfer MT102 message.
Receiver Charge Amount
If you select the option for settlement of the Receiver Charges as “Included in Settlement amount, then you must specify the charge amount.
Specify the number of transactions allowed for a single MT102 message.
Console Limit Amount
Specify the limit for console transactions.
Console Debit Accounting Code
Specify the Debit Accounting Code.
Console Credit Accounting Code
Specify the Credit Accounting Code.
Console Cutoff (Hours)
Specify the hours for Console Cutoff.
Console Cutoff (Minutes)
Specify the minutes for Console Cutoff.
GPI Allowed
Check this box to indicate that the receiver of the MT103 message can accept gpi payment from our bank.
GPI Receiver Charge
The receiver charge to be populated for outgoing payment when the charge bearer option is OUR.
GPI IN Cutoff Days
No of days to be considered for gpi cut off for incoming gpi payment.
GPI OUT Cutoff Days
No of days to be considered for gpi cut off for outgoing gpi payment.
GPI IN Cutoff (Hours)
Specify the hours to be considered for gpi cut off for incoming gpi payment.
GPI IN Cutoff (Minutes)
Specify the minutes to be considered for gpi cut off for incoming gpi payment.
GPI OUT Cutoff (Hours)
Specify the hours to be considered for gpi cut off for outgoing gpi payment.
GPI OUT Cutoff (Minutes)
Specify the minutes to be considered for gpi cut off for outgoing gpi payment.
You can invoke “Sender-Receiver Agreement Summary” screen by typing ‘PXSSRAGM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Special Instructions Maintenance’ screen by typing ‘PXDSIMNT’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Host Code
The system displays the Host Code by default when you select New or Enter Query.
Branch
The system displays the selected branch of the logged in user.
Account Number
Specify the account number for which the special instruction needs to be maintained. Alternatively, you can select the account number from the option list. The list displays all valid account numbers maintained in the system.
Currency
The system displays the currency of the selected account number.
Specify the special instruction in free format text.
You can invoke “Special Instructions Summary” screen by typing ‘PXSSIMNT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Cover Suppression Maintenance’ screen by typing PMDCSPRL in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Host Code
The system displays the host code of the selected branch of logged in user.
Rule Number
Specify the Rule Number.
Rule Exception
Specify the Rule Exception.
Condition
Specify the rule condition using a combination of Elements, Operators, Functions and Logical Operators.
Element
Specify the attributes that can be used for condition builder. Alternatively, you can select the attributes from the option list. The list displays all valid attributes maintained in the system.
Operators
Select the standard operators to define conditions from the drop-down list. Following are the options available in the drop-down list:
Functions
Select standard functions to define conditions from the drop-down list. Following are the options available in the drop-down list:
Logical Operators
Select the standard logical operators to define conditions from the drop-down list. Following are the options available in the drop-down list:
Cover
Check this box to indicate whether cover message is suppressed or not.
You can invoke “Cover Suppression Summary” screen by typing ‘PMSCSPRL’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can enrich an incoming SWIFT message according to the rules specified for a message type in this screen before the processing of incoming message is initiated.
You can invoke “Message Enrich Rules Maintenance” screen by typing ‘PXDRLECH’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Message Type
Specify the type of the message, say, MT103. Alternatively, you can select the message type from the option list. The list displays all valid message types maintained in the system.
Message Tag
Specify the tag or field of the selected message type.
Sequence
Displays the sequence of this tag in the message.
Status
Displays the condition of the tag.
Priority
Specify the priority of the enrichment condition.
Condition
Specify the enrichment condition for the message by using a combination of String function, Logical Operator and Operator.
String Functions
Select the string function for constructing condition from the drop down list.
Logical Operators
Operators
Action Elements
Select one of the available enrichment functions for enriching the value in the selected message tag of the message type.
Parameter 1
Specify the parameter 1 value if expected by the selected enrichment function.
Parameter 2
Specify the parameter 2 value if expected by the selected enrichment function.
Click on the ‘Exclusion’ button to invoke the following screen.
Message Type
Displays the message type.
Sender BIC
Specify the sender BIC. Alternatively you can select the sender BIC from the option list. The list displays all valid BICs maintained in the system.
Currency
Specify the currency. Alternatively you can select the currency from the option list. The list displays all valid currencies maintained in the system.
You can invoke “Message Enrich Rules Summary” screen by typing ‘PXSRLECH’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can enable translation of information of the parties involved in the payment from ‘D’ option (names and addresses) to appropriate ‘A’ option (BIC codes).
This information is used during the STP of an incoming message to convert the names and address information to the appropriate BIC code of the parties mentioned in the message.
You can invoke the ‘D to A Maintenance’ screen by typing ‘PMDDAMNT’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Host Code
BIC Code
Specify the BIC codes. Alternatively, you can select the BIC code from the option list. The list displays all valid BIC codes maintained in the system.
BIC Code Description
The system displays the description (name of the entity) of the BIC codes.
Address Line1 through to Address Line4
Specify the address line 1 to 4 maintained for the BIC code Address Details mentioned in all of the input lines is compared with name and address received in the message to resolve the BIC Code. The details in these lines should match for successful conversion.
You can invoke “D to A Converter Summary” screen by typing ‘PXSDAMNT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Cover Queue Maintenance’ screen by typing ‘PXDRLSTP’ in the in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Host Code
The system displays the host code when you click New or Enter Query.
Message Type
Specify the Message type from the list of values.
Field Name
Specify the name of the field.
Field Type
Select the required field type. Choose between the following:
Field Logic
Specify the field logic.
Error
Click the Error link to specify any error messages.
Show Rule
Click the Show Rule link to specify or modify the Rule Maintenance parameters.
From the Cover Queue Rule Maintenance screen, click the Error link.
Error details of the error encountered in setting up the rules can be viewed here.
Source
Displays the source of error.
Error
Displays the error details.
From the Cover Queue Rule Maintenance screen, click the Show Rule link.
Priority
The system specifies the priority by default.
Condition
Specify the Rule Condition.
Result
Select the required result. Choose among the following:
Queue Name
Specify the required Queue Name from the list of values.
Status
Specify the status of the message that should be set for the rule condition. Choose among the following:
Reason
Specify the reason code from the list of values for each rule condition, if applicable.
Cover Required
Check this box if cover is required for a particular rule condition.
Suppress Message
Check this box if message must be suppressed for a particular rule condition.
You can invoke “Cover Queue Rule Summary” screen by typing ‘PXSRLSTP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Clearing Code Maintenance’ screen by typing ‘ISDCTMEX’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Country Code
Select the required code from the LOV.
Member ID/Clearing Code
Specify the Member Id/Clearing Code.
Member ID/Clearing Code Description
Specify the description of Member Id/Clearing Code.
Network Code
Select the required network code from the LOV.
Network Description
Specify the description of network.
Bank Name
Address 1 -4
Specify the address of the bank in the lines specified.
Own Clearing Code
Specify the required code from the LOV.
Clearing Code Indicator
Select the required clearing code indicator. The values are Yes and No.
Bank ID code
Specify the description of the BIC Code.
Customer Number
Select the Customer Number from the LOV.
Country Name
Specify the name of the country.
Clearing Code Type
Specify the Clearing Code Type.
Clearing System Proprietary
Specify the Clearing System Proprietary details.
Clearing system Code
Specify the clearing system code details.
You can invoke “Clearing Code Summary” screen by typing ‘ISSCTMEX’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Reconciliation External Accounts Maintenance’ screen by typing ‘PXDXTACC’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Reconciliation Class
Specify the Reconciliation Class.
External Account
Specify the External Account.
External Entity
Specify the External Entity
Alternate External Account
Specify the Alternate External Account
Home Branch
Specify the Home Branch.
You can invoke “Reconciliation External Accounts Summary” screen by typing ‘PXSXTACC’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
In addition to the maintenances specific to Cross-border payments, the common maintenances given below are also used for processing –
You can invoke the ‘MT101 Parameters Maintenance’ screen by typing ‘PXD101PM’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Specify the following fields:
Host Code
This is auto- populated by the system once you click on New. The host code indicates the host code of the user’s logged in .
Sender / Receiver
Specify or search and select a Bank from the list of values which can be either the Sender or Receiver of incoming/outgoing MT101. The value to be input or selected is a 6 digit bank identifier which is actually the first 6 digits of a BIC code. This bank identifier would refer to all of the bank’s branches (BICs) in a country.
Maximum Number of Incoming Transactions
Specify the Maximum Number of Incoming Transactions allowed in an incoming MT101 from the Bank specified above.
Maximum Number of Outgoing Transactions
Specify the Maximum Number of Outgoing Transactions allowed in an outgoing MT101 to the Bank specified above.
You can invoke “MT101 Parameters Summary” screen by typing ‘PXS101PM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Once you have specified the search parameters, click ‘Search’ button. The system displays the records that match the search criteria with the following details:
ASI – Instructing Party Agreement maintenance capture relationship between an Instructing party BIC (non-FI BIC), one or more Sender bank, Customer number and one or more Account numbers of the Customer available in the system.
You can invoke the “ASI-Instructing Agent Agreement” screen by typing ‘PXDINAGM’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow . Click new button on the Application toolbar.
Host Code
This is auto-populated by the system once you click on New. The host code indicates the host code of the user’s current logged in branch.
Instructing Party
Specify or search and select the Instructing party from the list of values.
Ordering Customer
Specify or search and select the Ordering Customer from the list of available customers maintained in the system.
Amount Limit
Specify the Amount Limit per transaction in the incoming MT101 received from the Instructing party on behalf of the Ordering customer.
Specify the currency to be used for the transaction in the incoming MT101.
Instructing Party Name
System displays the name of the Instructing party once the Instructing Party code is specified.
Cutoff Hour
Specify the cut off hour for the transaction in the specified currency present in the incoming MT101.
Cutoff Minute
Specify the cut off minute for the transaction in the specified currency present in the incoming MT101.
Allowed
Click this button to indicate that the account number(s) added to the account number grid are allowed for the transaction.
Disallowed
Click this button to indicate that the account number(s) added to the account number grid are disallowed for the transaction.
Account number
Click the add row icon in the grid to Specify or search and select a customer account number available in the system.
Sender
Click the add row icon in the grid to specify or search and select a Sender bank identifier from the LOV. The value to be input or selected is a 6 digit bank identifier which is actually the first 6 digits of a BIC code.
You can invoke “MT101-Instructing Agent Agreement Summary” screen by typing ‘PXSINAGM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
ASI – Ordering Customer Agreement maintenance captures relationship between a Customer Number and one or more Sender bank.
You can invoke the “ASI-Ordering Customer Agreement” screen by typing ‘PXDORAGM’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Click new button on the Application toolbar.
Host Code
This is auto-generated by the system once you click on New. The system indicates the host code of the logged in user.
Specify or search and select the currency used for transaction in the incoming/outgoing MT101 message, from the list of values.
Ordering Customer
Ordering Customer Name
This is automatically displayed once you select the Ordering Customer.
Amount Limit
Specify the Amount Limit for each transaction in the incoming/outgoing MT101 message.
Cutoff Hour
Specify the cut off hour for the transaction in the incoming/outgoing MT101 message.
Cutoff Minute
Specify the cut off minute for the transaction in the incoming/outgoing MT101 message MT101.
Allow Only Outgoing MT101
Check this box if only Outgoing MT101 message is allowed for the ordering customer.
This grid capures the allowed Sender BICs for receiving MT101 on behalf of the ordering customer. This could be the BIC of the ordering customer or any other bank including Forwarding agent.
Bank Code
Click the add row icon in the grid to specify or search and select a Sender BIC from the list of available BICs.
You can invoke “MT101-Ordering Customer Agreement Summary” screen by typing ‘PXSORAGM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Once you have specified the search parameters, click ‘Search’ button. The system displays the records that match the search criteria with the following details.
Forwarding Agent – ASI Agreement maintenance captures this bank’s relationship with an Account Servicing Institution (ASI) (any other bank) and one or more account numbers (optional) maintained at the ASI.
You can invoke the ‘Forwarding Agent-ASI Agreement’ screen by typing ‘PXDFWAGM’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button.Click new button on the Application toolbar.
Host Code
Account Servicing Institution Bank
Specify or search and select the Account Servicing Institution Bank from the list of values. The value to be input or selected is a 6 digit bank identifier which is actually the first 6 digits of a BIC code. This bank identifier would refer to all of the ASI bank’s branches (BICs) in a country.
Amount Limit
Specify the Amount Limit of each transaction in the outgoing MT101 message.
Specify the currency used for transaction in the outgoing MT101.
Account Servicing Institution Bank Name
Specify the name of the Account Servicing Institution.
Cutoff Hour
Specify the cut off hour for the transaction in the specified currency included in the outgoing MT101.
Cutoff Minute
Specify the cut off minute for the transaction in the specified currency included in the outgoing MT101.
These are accounts of the ordering customers at the ASI for which MT101 can be processed by the ASI. This is an optional set of fields.
Allowed
Click this button to indicate that the account number (s) added to the Account number grid are allowed for the transaction.
Disallowed
Click this button to indicate that the account number(s) added to the Account number grid are disallowed for the transaction.
Account Number
Click the add row icon in the grid to specify the account number.
You can invoke “MT101-Forwarding Agent-ASI Agreement Summary” screen by typing ‘PXSFWAGM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the “RMA or RMA Plus Details Maintenance” screen by typing ‘PMDRMAUP’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button. Users having access to Branches would only be able to view the RMA/RMA+ authorization details. Only Head Office users would also be able to modify RMA/RMA+ authorization records or create new records. Click new button on the Application toolbar.
RMA Record Type
The system would indicate if this is a RMA or RMA+ authorization record based on the details of the uploaded or manually created RMA authorization record.
Note
If the uploaded RMA file has included or excluded Message Types in different Message categories, then this would be RMA+ record. If not, the record is an RMA record.
Issuer
Select the required BIC of bank branch that has issued the authorization to send All or particular message types (in case of RMA+) to them from the available list of values.
RMA Type
Specify the RMA Type. Choose between Issued and Received from the drop down.
Valid From Date
Specify the start date of validity of RMA authorization
Correspondent
Select the BIC of bank branch which has received the authorization from Issuer bank from the list of values.
RMA Status
Select the status of the RMA from the drop down. The options are Enabled, Revoked, Deleted and Rejected.
Note
Only ‘Enabled’ RMA authorizations are used for RMA validation.
Valid To Date
Specify the End date of validity of RMA authorization.
Message Category
Select the required Message Category from the drop down.
Include/Exclude Flag
If this is being created as RMA+ record, select the flag for each Message category indicating ‘Include’ or ‘Exclude’ of one or multiple or ALL Message Types (MTs) that are authorized by the Issuer bank.
Message Type
If this is being created as RMA+ record, then specify a list of ‘Included’ or ‘Excluded’ the Message Types to be added for each Message Category.
Note
As mentioned above, any modifications to existing authorizations would be allowed only from Head Office
Note: In reality, RMA Status cannot be changed to any option as it depends on who is the Issuer BIC, current status and other factors. However, these status changes would actually happen in the RMA/RMA+ module of SAA and the Modification facility would only allow Ops users to manually replicate the status in this maintenance (if they cannot wait till the next RMA upload).
A new authorization would be possible to be created by copying an existing authorization and then modifying the same.
Modifications to existing authorizations as well as creation of new authorizations would need approval by another user or by the maker (if the branch and user supports Auto-authorization facility).
Note
If RMA+ validation fails, then MT191 is still generated but with a new status called ‘Withheld’ status. This status means that the message was generated but has been “held back” i.e. not “handed off” to EMS.
Note
If the RMA/RMA+ validation fails, then system does not send the message.
You can invoke “RMA or RMA Plus Details Summary” screen by typing ‘PMSRMAUP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can invoke the ‘Alpha Code Maintenance’ screen by typing ‘PXDALMNT’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button.Click new button on the Application toolbar.
Alpha Code
Specify the Alpha Code.
Description
Specify the Description.
Short Code
Specify the Short Code.
Identifier
Specify the Identifier.
Description
Bank Code
