Automated Clearing House Networks facilitate transmission and settlement of electronic payments originated by individuals, businesses, financial institutions and government organizations. Domestic low value payments are local payments or payments limited to a specific region. Depending on the network specifications, messages are processed in batch mode and dispatched at the specified time during the day.
Below listed functionalities for SEPA credit transfer (SCT) are explained in this user manual:
For Domestic Low value payments, the payment type is ‘ACH’.
Below transaction types are supported for ACH payments:
You can perform ACH outgoing transaction. All transactions that are entered using this screen has payment type as ‘ACH” and transaction type as ‘Outgoing’. You can invoke ‘ACH Outgoing Payment’ screen by typing ‘PADOTONL’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Click new button on the Application toolbar..
You can specify the following fields:
Transaction Branch code
The system defaults the transaction branch code with the user’s logged in branch code.
Host code
The system defaults the host code of transaction branch.
Source Code
For manual transactions source code is defaulted as MANL. This denotes that the it is a manually input transaction.
Network Code
The system displays the network code if only one Network is maintained with payment type as ACH for the host code. If more than one networks are present, you can select the network code from the available list of values
Transaction Reference number
The system generates the transaction reference number. For more details on the format, refer the Payments Core User Guide.
User Reference Number
The system defaults transaction reference number. However you can modify this.
Click ‘Main’ tab to capture the Creditor/ Debtor/ Payments details:
Specify the following details
Debtor Account Number
Specify the debtor account number. Alternatively, you can select the debtor account number from the option list. The list displays all open and authorized accounts as available in External Account Maintenance.
Account IBAN
The system defaults the account IBAN based on the debtor account number field selected.
Account Currency
The system defaults account currency based on the debtor account number selected.
Account Branch
The system defaults the account branch based on the debtor account number selected.
Debtor Name
The system defaults debtor name based on the debtor account number selected.
Debit Amount
The system populates this field as the transfer amount converted in debtor account currency on enrich.
Customer
This field is defaulted as the customer ID of the Debtor account chosen.
Customer Service Model
Specifies the Customer Service Model. This is displayed if customer is linked to a service model.
SSI Label
Select the required SSI label from the list of values.
Note
This list will be populated with valid SSI Labels, applicable for the customer and the Network.
Creditor Account Number
Specify the creditor account number.
Account IBAN
Specify the creditor account IBAN.
Note
If ‘IBAN Check’ is enabled for the network then, you must specify creditor account IBAN and creditor details.
Creditor Name
Specify the creditor name.
Creditor Bank BIC
Specify the creditor bank code. Alternatively, you can select the creditor bank code from the option list. The list displays all open and authorized Bank Codes/BIC codes available in the local bank directory. This is listed based on the ‘Bank Network Identifier’ maintained for Network maintenance (PMDNWMNT).
Note
In case the Creditor Bank BIC is not specified, then the system has an additional feature by which you can use the beneficiary IBAN. However, the IBAN validation must be specified in Network maintenance (PMDNWMNT).
Note
For ACH Outgoing payments initiated from Upload channels like C2B, REST, SOAP & JSON over JMS, Creditor Bank BIC is resolved during STP processing.
Booking Date
The system defaults the booking date as application server date.
Instruction Date
The system defaults the Instruction date as current system date. However you can select a future date as Instruction Date.Debit currency/Credit currency & Network holiday checks are applicable for Instruction Date.
Activation Date
Activation date is derived as Instruction Date – Debit Float days as maintained in Process cutoff maintenance. Holiday check is done for Activation date based on Branch holidays maintained if Branch holiday check is applicable for the Network.
Credit Value Date
The system defaults as Instruction Date.
Debit Value Date
The system defaults as Activation Date.
Transfer Currency
The system defaults transfer currency if the network allows only single currency as per Network currency preferences (PMDNCMNT).
If multiple currencies are allowed then the system allows you to specify the transaction currency. Alternatively, you can select the transaction currency from the option list. The list displays all valid transaction currencies maintained in the system.
Transfer amount
Specify the transaction amount.
Exchange Rate
Specify the exchange rate if debit account currency and credit account currency is different from the transfer currency. The system retains the input value and validate the same against override and stop variances maintained in the Network preference.
If exchange rate is not specified, then the system populates the exchange rate on enrich or save, if the transfer amount is less than small FX limit maintained.
System populates exchange rate, debit amount and charge/tax amounts when you click on the Enrich Button. If exchange rate pick up or charge pick up fails, then the system throws an error. User can provide the values and proceed with the transaction.
FX Reference Number
Specify the FX Reference Number.
Remarks
Specify the internal remarks, if any.
You can view the pricing details populated by system in this screen.
The following details are available:
Pricing Component
The system defaults the pricing component based on the Pricing code linked in Network Currency Preferences.
Pricing Currency
The system defaults the pricing currency.
Pricing Amount
The system defaults the pricing amount from Pricing Value Maintenance screen (PPDVLMNT) as applicable for the payment value date, Payment Source code and Debit Customer Service Model. However you can modify this value.
Note
Currency conversions related to charge computation are completed and final amount is populated component wise in the Pricing Tab.
Waived
The system defaults the waiver. However you can modify this value.
Note
If charge/tax is already waived at price value maintenances, then you cannot uncheck the waiver flag.
Debit amount
System defaults the customer debit amount for charge/tax.
UDF
Click this link to specify the user defined fields.
MIS
Click this button to specify the MIS fields.
Specify the additional details in this screen. Click on the ‘Additional Details Button’ to invoke this screen.
Specify the debtor and creditor details:
Address Line 1
Specify the address of the debtor.
Address Line 2
Country
Specify the Country of residence of the debtor. Alternatively, you can select the country from the option list. The list displays all valid country codes maintained in the system.
Birth Date
Select the date of birth of debtor from the adjoining calender.
Province Of Birth
Specify the province of birth of the debtor.
City Of Birth
Specify the city of birth of the debtor.
Country Of Birth
Specify the country of birth of the debtor. Alternatively, you can select the country from the option list. The list displays all valid country codes maintained in the system.
Organization Bank ID
Specify the organization bank id of debtor.
Private Identification
Specify the private identification number of debtor.
Identification Issuer
Specify the identification issuer details.
Identification Scheme Code
Specify the identification scheme code.
Identification Scheme Proprietary
Specify the identification scheme proprietary details.
Address Line 1
Specify the address of the creditor.
Address Line 2
Country
Specify the Country of residence of the creditor. Alternatively, you can select the country from the option list. The list displays all valid country codes maintained in the system.
Birth Date
Select the date of birth of creditor from the adjoining calender.
Province Of Birth
Specify the province of birth.
City Of Birth
Specify the city of birth of the creditor.
Country Of Birth
Specify the country of birth of the creditor. Alternatively, you can select the country from the option list. The list displays all valid country codes maintained in the system.
Specify the organization bank id of creditor.
Specify the private identification number of creditor.
Name
Specify the debtor name.
Birth Date
Select the debtor date of birth from the adjoining calender.
Province Of Birth
Specify the debtor province of birth.
City Of Birth
Specify the city of birth of debtor.
Country Of Birth
Specify the country of birth of the debtor. Alternatively you can select the country of birth from the option list. The list displays all valid country codes maintained in the system.
Specify the organization bank id.
Specify the private identification number.
Specify the identification scheme proprietary.
Name
specify the creditor name.
Birth Date
Province Of Birth
Specify the creditor province of birth.
City Of Birth
Specify the city of birth of creditor.
Country Of Birth
Specify the country of birth of the creditor. Alternatively you can select the country of birth from the option list. The list displays all valid country codes maintained in the system.
Note
You can capture the below details in this screen.
Category Purpose Code
Specify the category purpose code.
Category Purpose Value
Specify the category purpose value.
Purpose Code
Specify the purpose code.
Local Instrument Code
Specify the local instrument code.
Local Instrument Value
Specify the instrument value.
Note
Remitter Reference
Specify the remitter reference number.
Remitter Code
Specify the remitter code.
Remitter Information Issuer
Specify the remitter information.
Additional Remittance Info
Specify the additional remitter information any.
Payment Details
Specify the payment details.
Note
Only one of structured Payment Details or Unstructured Payment details may be present
Payment Details
The system performs the following mandatory field checks and the referential checks during the save of ACH outgoing payment transaction. If any of the below validation fails, then the transaction is rejected with an error code.
Following fields are mandatory for requesting ACH outgoing payments:
If the source code is not MANL, then it is mandatory to specify the Source reference number.
Customer/Account status validation is done based on the status details available in External Customer maintenance/External Account maintenance.
Holiday check for instruction date is done based on the local branch holidays maintained.
Any validation failure from user interface screen throws error on transaction saving. You can check the error details from the respective error message displayed and can take re medial action before re-submitting.
Oracle Banking Payments allows you to process the outgoing ACH payment request received from SOAP or REST web services. All the transactions created based on the requests received from SOAP/REST web services are always auto authorized.
The system picks the booking date of the transaction as the application server date. Based on the debit account number through External Account Maintenance, the system derives at the debit account name, debit currency and debit customer.
The following fields are supported for a payment instruction received through REST services:
Initial validations as explained in section 2.2.5 are applicable for payment transactions received from channels as well.
If instruction date is a holiday, activation date is derived as next working day
In case of invalid accounts/bank codes, system does Bank/Account re-direction if any maintenance is available for the invalid codes.
Any validation exception moves the transaction to exception queue. For more details please refer to User Manual on Exception Queues.
You can view the summary in “ACH Outgoing Payments Summary” screen. You can invoke the ACH Outgoing Payments Summary screen by typing ‘PASOTONL’ in the field at the top right corner of the Application toolbar and clicking on the adjoining arrow button.
You can search for the records using one or more of the following parameters:
Once you have specified the search parameters, click ‘Search’ button. The system displays the records that match the search criteria. YAuthorization Status
The transaction authorization process involves the following steps for a payment transaction with Activation date as current date:
The system validates any debtor, creditor, bank, additional details specified for a payment transaction against the valid characters allowed for the network. If any field contains invalid SEPA character, then the transaction is moved to repair queue with error details.
Network Character Validation ise done for the R-transactions initiated manually for the following payment types:
This validation is done only on fields input by the user except LOV and drop-down fields.
If 'IBAN Validation Required' flag is checked for the network, then IBAN verification for Debtor IBAN, Creditor IBAN and creditor BIC is done against the IBAN format maintained for the respective country.
Please refer to Payments Core User manual for more details on IBAN check.
The duplicate check for a transaction is done during transaction processing if Duplicate check is applicable for the Source. Payment fields marked for duplicate check in Source Maintenance are matched with all the payments booked within the duplicate period. Booking date of the payments is considered for evaluating duplicate period.
Duplicate period is considered based on the number of days maintained for the source. If the maintenance is not available, then the duplicate check is not done.
If there are any matching payments with the fields identical with the payment being processed, then the payment is moved to Business Override Queue for further investigation.
Transaction cut off time validation is based on the Transaction Cut-off Time Maintenance (PMDCTOFF) screen. Transaction cutoff time check is done only for transaction with payment activation date is current date.
Transaction Cut-off time for the payment network and Transaction Type 'Outgoing' is fetched from the maintenance for the following combination:
Cut off time is derived as follows:
| Sl.No | Network | Transaction Type | Source | CSM | Customer | ||||||
| 1 | Network ID | Outgoing | Specific | Specific | Specific | ||||||
| 2 | Network ID | Outgoing | ALL | Specific | Specific | ||||||
| 3 | Network ID | Outgoing | Specific | Specific | ALL | ||||||
| 4 | Network ID | Outgoing | ALL | Specific | ALL | ||||||
| 5 | Network ID | Outgoing | Specific | ALL | ALL | ||||||
| 6 | Network ID | Outgoing | ALL | ALL | ALL |
If payment processing time is lesser than or equal to the Cut-off date time derived, then the payment is considered as 'Pre Cut-off' payment and proceeds with further processing.
If payment save date time or payment receipt date time exceeds the Cut-off date time derived then the payment is considered as 'Post Cut-off' payment and post cut off status is updated for the transaction.
If the flag 'Move forward to next working day' is checked then Activation date of the transactions which are post cut off is moved to next business day automatically.
User is allowed to force release the transaction with today's value date from post cut off Queue. Payments released from Post Cutoff queue would not undergo transaction cut-off time checks again.
If sanction screening is required for the Network and the customer, request is sent to External Sanction System.
If the sanction check status of the transaction is 'Approved', then further processing continues. If the contract's sanction check response status is 'Override' or 'Rejected' or 'Timed Out', then transaction is logged in 'Sanction Check Exception Queue’ and the processing of the transaction is stopped at this stage.
Charge and tax for ACH Payment transactions are calculated based on the Pricing Code linked to Network Currency Preferences (PMDNCPRF) screen.
For more details on pricing, please refer Pricing Use Manual.
For a cross currency payment transaction where debit currency and transfer currency are different, exchange rate maintained for the transaction branch in the core system is considered.
If small FX limit is defined in Network Currency Preferences, then the auto rate pick up happens only if the transfer amount is within the small FX limit. If Small FX limit is not maintained auto rate pick up is done for all cross currency payment transactions without any limit check.
For an outgoing transaction limit check is based on the small FX limit specified in Network Preferences for transaction type 'Outgoing’.
Exchange Rate Type is based on Network preferences maintained. Buy/Sell indicator is derived by the system based on the currency pair maintenance available.
If the transfer amount is above the small FX limit specified, system checks whether External Exchange Rate is applicable in Network Preferences.
If external system is available then system interfaces with external system for receiving the exchange rate.
Payment contract is moved to Exchange Rate Queue in the following cases with proper error code details and exchange rate status:
Payment contract is moved to External Exchange Rate queue in the following cases:
It is possible to provide exchange rate manually from Queue screen so that transaction proceeds with further processing.
Payments send debit accounting entries pertaining to payment amount and charge/tax amounts to external DDA system for credit approval.
External Credit Approval is done for all the external accounts for which ‘External Credit Approval Required’ flag is enabled. ECA system for the credit check is derived based on the External Account maintenance.
If the ECA response status for a payment transaction is 'Approved', then further processing continues. If ECA validation fails i.e. the status is 'Override', 'Rejected', or 'Timed out', then the transaction is logged in ECA Exception queue.
The system checks the network cutoff time based on the cut off time maintained for the network. The system considers the application server time for cut off time check. Transactions which failed cut off time check is moved to Post Network Cutoff Queue.
Debit liquidation accounting entries have both payment entries and charge/tax entries. Accounting details are handed off to accounting system with debit/credit liquidation accounting code linked at Network Currency preferences.
SCT batch processing mode (‘Batch Processing Option’) is a value-added service of the STEP2 SCT Service in which files from sending Direct Participants contain batches of Payments Messages which are already sorted per the receiving Direct Participant.
The expected benefits from this variant of the standard bulk processing are better performances, higher processing capacity and lower transaction costs.
The SCT Batch Processing mode can be used for sending Payment Messages in favour of another Direct Participant or a Reachable BIC. The sending Direct Participant is responsible for grouping the Payment Messages that are for Reachable BICs per receiving Direct Participant.
The Batch Processing Option will always route the batches to the receiving Direct Participant indicated by the sender as Instructed Agent provided that:
The linked Direct Participant has to be stored in dispatch details as Instructed agent if the creditor agent is an indirect BIC for each payment, Batch processing is applicable for each payment record for dispatch, if the Instructed agent is enabled for Batch processing.
The following messages types are exchanged using the Batch Processing Option:
Batches must be arranged in the same order of message types.
Dispatch files in batch processing mode has to be generated with I extension with File name as below:
YYMMDDHHMMSS, which is the file creation date and time, and NNN, which is an incremental number starting from 000 that is reset to 000 every time DD (date) Changes
Future dated ACH transactions are processed by separate jobs. Processing of transactions will be completed till sanction check on booking date itself. During beginning of day, future dated transaction job picks up transactions with Activation date as current date. Transaction processing starts from initial validations again, on activation date.
Future dated transactions job should be run after rate refresh and this has to be operationally handled.
In addition to Currency and Network Holidays, Branch holidays is considered in determining the Value date and Activation date for SWIFT, ACH, and RTGS payments.
Processing Branch holidays is considered in the Dates resolution only if a particular parameter in Network Preferences for the ‘Outgoing’ or ‘Incoming’ transaction type is checked.
This new parameter is called ‘Consider Branch Holidays in Dates resolution’.
This parameter is added to this maintenance under a new sub-section called “Value Dating Preferences”.
You can view the ACH outgoing transaction in this screen.
You can invoke “ACH Outgoing Payments” screen by typing ‘PADOVIEW’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Click new button on the Application toolbar..
Transaction reference Number
Specify the transaction reference number. Alternatively, you can select the transaction reference number from the option list. The list displays all valid transaction reference numbers maintained in the system.
The system displays all the fields in the below mentioned tabs based on the transaction reference number selected.
You can view debtor/Creditor details in this screen. Click on the ‘Main’ tab to invoke this screen.
You can view pricing details in this screen. Click on the ‘Pricing’ tab to invoke this screen.
Click on the ‘Accounting Details’ tab to invoke this screen.
You can view the consolidated accounting entries of the transaction.
Click on the ‘UDF’ button to invoke this screen.
You can specify user defined fields for each transaction.
Note
You can invoke ‘UDF’ screen by typing ‘PMDTRUDF’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Click new button on the Application toolbar.
Click on the ‘MIS’ button to invoke this screen.
You can specify the MIS details in this sub-screen.
Note
You can invoke ‘MIS’ sub-screen by typing ‘PMDTRMIS’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Click new button on the Application toolbar.
Background job are available for reading the incoming SCF file from the designated folder and to populate the data into staging table. File reference number is generated. Transaction details received in a single file can be identified by file reference number.
Instructed Agent BIC in pacs.008 message is considered as transaction branch BIC. Transaction branch BIC is compared with branch codes available in Core maintenance for branches to ascertain Branch code and related Host code.
In File parameters Maintenance, you can specify for File type SCF and for a Host code which Network code is applicable. This Network code will be applicable for all transactions listed in the Incoming file. Payment type linked to the Network is considered as the transaction payment type.
Inter bank settlement date in pacs.008 message is considered as payment debit value date for incoming type of transaction.
Credit settlement account is the credit IBAN received in the message. This has to be a valid IBAN available in External account mapping. System derives the account number based on the IBAN from the same maintenance.
Debit Account is fetched from the accounting code maintained in Network currency preferences for the transaction type Incoming.
For incoming payments file receipt accounting of the consolidated amount of pacs.008 and pacs.004 messages is supported. Receipt accounting code can be maintained in Network Currency preferences for Incoming transaction type.
Transaction account and offset account is maintained as part of accounting code itself. Event for accounting entries is ‘RCLG’.
The resulting accounting entries are as following:
Accounting value date is settlement date a received in the file. No External Creit approval is performed for receipt accounting.
There is a provision for handing off accounting entry details to external accounting system.
Incoming payments are processed in PA module in the following steps:
Debit currency is considered as transfer currency for incoming transactions
System performs mandatory field checks & referential checks during transaction saving.
Below fields are mandatory for booking ACH incoming payment:
Following parameters are validated with the static maintenances available for existence of the values:
If any of the above validation fails, transaction is rejected with proper error code. This transaction will be available in Repair queue with error details.
Amount of the transaction should be within the minimum and maximum defined for the Network, Transaction type ‘Incoming’ & transaction currency combination as maintained in Network Currency Preferences (PMDNCPRF).
In case the transaction amount breaches the transaction limit specified for minimum or maximum amount, an override will be logged and this transaction will be moved to the Repair queue
If ‘IBAN validation required’ flag is checked for the network, then IBAN verification for Debtor IBAN & debtor BIC is done against the IBAN format maintained for the respective country.
Identification of duplicate transactions done for a period as maintained in Source Maintenance.
The payment is moved to Business Override Queue for further investigation In case of a duplicate transaction.
If sanction screening is required for the Network (for incoming transaction type) and the customer, request is sent to External sanction system.
System verifies whether sanction check system is applicable in Network Preferences Maintenance, for ‘Incoming’ transaction type and initiates sanction check validation.
For more information refer ‘Computation of Charge and Tax’ section in this user manual.
Exchange Rate pick up is based on the FX limits maintained in Network preferences for transaction type ‘Incoming’.
For each transaction being processed, debit and credit liquidation are done to the respective settlement accounts. Accounting details are handed off to the accounting system for posting the entries.
Following notifications are generated for incoming payments.
| Notification Code | Details | Text | |||||||
| PM_ACH_CR_1 -Credit | Notification for incoming payment -On Credit Liquidation | Credit Account | Account <Credit Account>is credited for <Credit Currency >,<Credit Amount> on <Credit Liquidation | Date> for Payment Reference Number<Transaction Reference Number>. Charge or Tax component amd amount deducted details are <Charge Currency> <Charge Amount> | |||||
| Credit Account currency | |||||||||
| Credit Amount | |||||||||
| Credit liquidation date | |||||||||
| Transaction Reference number | |||||||||
| Charge/Tax debit amount | |||||||||
| Charge/Tax debit currency |
You can view the ACH Incoming transaction in this screen.
You can invoke “ACH Incoming Payments” screen by typing ‘PADIVIEW’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Click new button on the Application toolbar..
Note
Note
It is now possible to manually create an ACH Incoming Payment by providing the details in the Input screen.
You can invoke the “ACH Incoming Payments Input” screen by typing ‘PADITONL‘ in the field at the top right corner of the application tool bar and clicking on the adjoining arrow button.
You can view Debtor/Creditor/Payment details in this screen. Click on the ‘Main’ tab to invoke this screen.
Transaction Branch Code
This field is populated as user’s logged in branch
Host Code
This field is defaulted as logged in Host.
Network Code
If only one Network is maintained for with payment type as ACH for the host code, the same will be defaulted in this field.
In case multiple networks are found for the same combination, all applicable networks will be listed for the field.
Source Code
For manually input transactions, source code is defaulted as MANL.
Internal Transfer
Check this box to indicate that creditor account is internal to Bank and dispatch to Network is not applicable.
All open and authorized accounts maintained in External Account maintenance are listed. You can select the creditor account. The list of values search page displays the Account IBAN along with Customer No & Customer Name.
Creditor Details
Creditor Account IBAN
Based on the creditor account number, IBAN appears by default in the IBAN field, if it is available.
Account Currency & Creditor Name
These fields are populated based on creditor account chosen.
Credit Amount
This field as populated as the transfer amount converted in credit account currency. The Exchange rate pick up is based on network preferences.
Debtor Details
Debtor Account Number & Account IBAN
Either debtor account number or account IBAN is mandatory. If the network is ‘IBAN Check’ enabled, it will be mandatory to specify debtor account IBAN
Debtor Name
Specify Debtor Name.
Debtor Bank Code
All open and authorized Bank Codes/BIC codes available in local bank directory are listed in this field. The listing is based on the ‘Bank Network Identifier’ maintained for Network maintenance (PMDNWMNT).
You can choose the appropriate bank code. This is a mandatory field.
Booking Date & Value date
Both booking date & Instruction date are defaulted as current date. Instruction date can be modified as a back date or forward date.
Transfer Currency
If the network allows only single currency as per Network currency preferences screen (PMDNCMNT), this currency will be populated as transfer currency. If multiple currencies are allowed, you can select from the list of allowed currencies.
Transfer Amount
Specifies the amount received in the incoming payment. This is a mandatory field.
Exchange Rate
If transfer currency & creditor account currency are different, then exchange rate can be provided by the user. The system retain the input value and validates the same against override and stop variances maintained in Network Preferences screen.
If exchange rate is not a user input, the system picks up the exchange rate during ‘Enrich’ provided the transfer amount is less than the small FX limit maintained. If the exchange rate is not available, system displays an error message.
If transfer amount is more than the small FX limit and if external exchange rate is applicable, then exchange rate pick up will happen during transaction processing.
You can invoke the ‘Incoming Payments Summary’ screen by typing ‘PASITONL’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button.Click new button on the Application toolbar.
You can click ‘Search’ button to view all the pending functions. However, you can to filter your search based on any of the following criteria:
When you click ‘Search’ button the records matching the specified search criteria are displayed.
Note
Future dated transactions job should be run after rate refresh. This must be handled operationally.
When R- transactions are received, system tries to match the transaction with the original payment sent irrespective of the original transaction status. Transactions pending in exception queues / future value queues will also be considered for matching.
If the original transaction fetched is not found or not in the expected status, system will move the R- message to an exception queue with appropriate error message.
You can verify the details of original transaction, initiate appropriate steps for moving the transaction to the required status and then re-initiate the processing of R-message.
More information on R- Messages Queue is available in the Queues User Manual.
You can invoke the “Return of Incoming Payment” screen by typing ‘PADINRTN‘ in the field at the top right corner of the application tool bar and clicking on the adjoining arrow button. You will be allowed to perform return operations only if the transaction processing status is Completed for incoming transactions.
Return Reference Number
The system displays the Return Reference Number by default.
Return Date
The system displays the Return Date as the current date by default.
Original Transaction Reference
You can select the Original Transaction reference of the incoming payment for which return is to be initiated. Only incoming transactions with payment type as ‘ACH’ and Transaction status ‘Processed’ are listed for this field.
On selecting the Original Transaction Reference ,the information related to the transaction is defaulted in the below listed fields:
Reject Code
Specify the Reject Code. Alternatively, you can select the Reject Code from the option list. The list displays all valid Reject Codes maintained in the system.
Note
Only the reject codes applicable for the payment network for the operation ‘Payment Re- turn’ are listed.
Reject Reason
The system displays the Reject Reason based on the selected Reject Code.
Originator Name
Specify the name of the Originator.
Originator Bank
Specify the Originator Bank. Alternatively, you can select the Originator Bank from the option list. The list displays all valid Originator Banks maintained in the system.
Note
You must either specify the Originator Name or the Originator Bank.
These fields are applicable while querying for a particular Return record which is rejected by the CSM
Reject Reference
The system displays the Reject Reference details.
Reject Received Date
The system displays the date on which the network reject was received.
Reject Code
The system displays the network reject code.
Reject Reason
The system displays the reason for Network Reject.
A recall happens when an Originator Bank requests to cancel a SEPA Credit Transfer. The recall procedure must be initiated by the Originator Bank within the number of days maintained as Recall days in Network Preferences after the execution date. A recall procedure is initiated for the following reasons:
Note
Only outgoing payment transaction in ‘Processed’ and ‘Future Valued’ status will be al- lowed to be selected for recall processing.
The system validates whether the original transaction is sent in Batch mode during Recall saving. The error message “Original transaction sent in Batch mode. Recall cannot be processed in bulk mode”, appears if the preference has changed subsequently to Bulk mode for the Assignee bank.
You can access the Outgoing Recall Input Screen by typing PADOTRCL in the field in the top right corner of the application tool bar and clicking on the adjoining arrow button.
Recall Reference Number
System defaults the recall reference number.
Recall Date
Specifies the date on which the recall was initiated. This date is defaulted as recall booking date.
Customer Initiated
Specify if the customer initiated the recall.
Original Payment Reference
Select the Original Payment Reference. All outgoing payments with payment type as ‘ACH’ and transaction status as ‘Processed’ or ‘Future Valued’ are listed for this field.
On selecting the Original Transaction Reference, the information related to the transaction is defaulted in the below listed fields:
Original Transaction Details
Recall Reason
While initiating a Recall request, you can specify the reason for the recall. All valid reject codes applicable for the Network for the operation ‘Payment Recall ‘ are listed for this field.
Reason Description
Based on the Reason code chosen ,reason description is defaulted.
Additional Recall Information
If the reason code entered is ‘FRAD’ then you can provide additional details in this field.
Originator Name
Specifies the name of the Originator.
Originator Bank
Specifies the name of the Originator Bank.
Note
Either Originator name or Originator Bank code can be captured as part of recall request
Response Details
Response details are populated if a positive response is received from Beneficiary bank.
Response Reference
Specifies the reference of the response.
Response Date
Specifies the date on which the response was created.
Reason Code
Specifies the reason code.
Reason Details
Specifies the reason for recall.
Compensation Amount
Specifies the compensation amount.
Network Reject Details
Network reject details are populated if the recall request sent is rejected by the CSM.
Reject Reference
Specifies the reference for rejection.
Specifies the date on which the reject was received.
Reject Code
Specifies the reject code.
Reject Reason
Specifies the reason for rejection.
You can invoke the ‘Recall Request Summary’ screen by typing ‘PASOTRCL’ in the field at the top right corner of the application toolbar and clicking the adjoining arrow button.Click new button on the Application toolbar.
If pacs.004 is received with reject reason ‘FOCR’ – Following Cancellation Request, as response of a recall request, then it is matched with original outgoing transactions with ‘Recall Requested ‘status.
On getting the parent transaction, further matching is done for the following fields:
Original transaction is marked as Returned. Return of the outgoing payment transaction is processed.
ECA and accounting related to incoming return is done.
No further action is allowed for a Recall Accepted transaction. Acceptance details are available for viewing.
Recall days validation is done for incoming recall message camt.056 received for payments sent.
If the validation is failed, the R-message will be logged in the R-message queue with the exception details.
You can access the Recall Response Input Screen by typing PADITRCL in the field in the top right corner of the application tool bar and clicking on the adjoining arrow button.
Recall requests received by the Beneficiary Bank are available in this screen.You can query the records and provide positive/negative response to the Originating Bank.
You can query the available records by providing the Incoming Recall reference number.
The following details is defaulted:
You can unlock the record and provide the recall response details:
Recall Response
You can either accept or reject the recall request received.
Reject Reason
The applicable reject code for the action can be selected
Reason Description
Reason description is populated based on the Reject reason chosen.
Charge Amount
If the recall request is accepted you can mention the charge amount applicable. This amount is reduced from the payment amount while returning the funds.
On clicking Process Charge button, the system defined charge is defaulted. The charge is populated based on the Recall Acceptance Price code maintenance for the transaction type ‘Incoming’ in Network Currency Preferences. You can override the defaulted charge.
Credit Validation File (CVF) is received from CSM for every ICF file to the sending Direct Participant indicating the success or failure of the validation process. A pre-settlement Reject message from CSM can be received in the form of pacs.002S2 report for any message originated by a bank:
The bulks which are partially accepted or rejected status’PART’ will be processed automatically by system.
Original transaction has to be in processing ‘Processed’ status with same dispatch details as in incoming reject report .On processing the network reject,
The Reject Reference Number, Reject date and reject code and reason will be available in Outgoing Transaction View screen.
In case this is rejected from the network , Original Transaction ID is matched with original recall reference. Original recall has to be in ‘Recall Requested’ status with same dispatch details as in incoming report.
Reject reference, Reject date, Reject code and reason can be viewed for original parent transaction. When a new recall is initiated, these details will be nullified.
Original Transaction ID is matched with original return reference. Original payment transaction has to be in ‘Returned’ status with return transaction dispatch details as in incoming report.
On receiving a network reject of positive response to Recall,Original Transaction ID is matched with original transaction reference.Original payment transaction has to be in ‘Returned’ status, recall status has to be ‘Approved’ with return transaction dispatch details as in incoming report.
Once the Recall request for Incoming Payment is refused, camt.029 will be sent to originating bank.In case, this is rejected from the network , network reject on the negative response of recall request . On receiving the network reject,Original Transaction ID is matched with original transaction reference. Original payment transaction has to be in ‘Processed’ status, recall status has to be ‘Refused’ with return transaction dispatch details as in incoming report
Note
