This section describes the set of unique keystrokes for LUX and OJET controls:
NOTE:
Disabled items will not receive keyboard focus and do not allow any interaction. Read-only items receive the keyboard focus.
This section contains information on the accordion keystrokes.
Target |
Key |
Action |
Collapsible header |
Space or Enter |
Toggle disclosure state. |
Tab |
Navigate to the next collapsible header and if none then the next element on-page. |
Shift+Tab |
Navigate to the previous collapsible header and if none then the previous element on-page. |
UpArrow or Left Arrow (RightArrow in RTL) |
Move focus to the previous collapsible header with wrap around. |
DownArrow or RightArrow (LeftArrow in RTL) |
Move focus to the next collapsible header with wrap around. |
Home |
Move focus to the first collapsible header. |
End |
Move focus to the last collapsible header. |
This section contains information on the Button Keystroke.
Target |
Key |
Action |
Push Button |
Enter or Space* |
Push the button. |
Toggle Button |
Enter or Space |
Toggle the button. |
Menu Button |
Enter, Space*, or DownArrow |
Open the menu. |
Esc |
Close the menu. |
NOTE:
Some types of Push and Menu buttons support the use of the Enter key and not the Space key.
This section contains information on the Buttonset One Keystroke.
Target |
Key |
Action |
Buttonset |
LeftArrow |
Navigate to the previous enabled button on the left, wrapping around at the end. |
RightArrow |
Navigate to the next enabled button on the right, wrapping around at the end. |
This section contains information on the OJET Canvas keystrokes.
Target |
Key |
LHS Activity List |
See OJET Context Menu for Keystrokes. See Canvas Diagram for Keystrokes. |
RHS Canvas Diagram |
This section contains information on the Canvas Diagram component
Key |
Action |
Tab |
Move focus to next element. |
Shift + Tab |
Move focus to previous element. |
Zoom in one level. |
Zoom out one level. |
0 (zero) |
Zoom to fit. |
Ctrl + Alt + 0 (zero) |
Zoom and center. |
PageUp or PageDown |
Pan up / down. |
Shift + PageUp or PageDown |
Pan left/right (RTL: Pan right/left). |
LeftArrow or RightArrow |
When focus is on a node, move focus and selection to nearest node left/right. |
UpArrow or DownArrow |
When focus is on a node, move focus and selection to nearest node up/down. |
Ctrl + Shift + Space |
Open/Close an active container node |
Move focus and selection to nearest node down in the container hierarchy |
Move focus and selection to nearest node up in the container hierarchy |
Alt + < or Alt + > |
Move focus from the node to a link. |
When focus is on a link, navigate between links clockwise or counter clockwise. |
When focus is on a link, move focus from a link to a start or end node. |
Ctrl + Space |
Select focused node / link. |
Ctrl + Space |
Multi-select node / link with focus. |
Shift + <node or link navigation shortcut> |
Move focus and multi-select a node or a link. |
Ctrl + <node or link navigation shortcut> |
Move focus to a node or a link but do not select. |
This section contains information on the Chart Component keystrokes.
Key |
Action |
Tab |
Shift + Tab |
UpArrow |
Move focus and selection to previous data item. |
DownArrow |
Move focus and selection to next data item. |
LeftArrow |
Move focus and selection to previous data item (on left). |
RightArrow |
Move focus and selection to next data item (on right). |
Shift + UpArrow |
Move focus and multi-select previous data item. |
Shift + DownArrow |
Move focus and multi-select next data item. |
Shift + LeftArrow |
Move focus and multi-select previous data item (on left). |
Shift + RightArrow |
Move focus and multi-select next data item (on right). |
Ctrl + UpArrow |
Move focus to previous data item, without changing the current selection. |
Ctrl + DownArrow |
Move focus to next data item, without changing the current selection. |
Ctrl + LeftArrow |
Move focus to previous data item (on left), without changing the current selection. |
Ctrl + RightArrow |
Move focus to next data item (on right), without changing the current selection. |
Ctrl + Spacebar |
Multi-select data item with focus. |
= or + |
Zoom in one level if zooming is enabled. |
- or _ |
Zoom out one level if zooming is enabled. |
PageUp |
Pan up if scrolling is enabled. |
PageDown |
Pan down if scrolling is enabled. |
Shift + PageUp |
Pan left in left-to-right locales. Pan right in right-to-left locales. |
Shift + PageDown |
Pan right in left-to-right locales. Pan left in right-to-left locales. |
Enter |
Drill on data item, categorical axis label, or legend item when drilling is enabled. |
This section contains information on the Checkbox keystroke.
Target |
Key |
Action |
Checkboxset |
Tab In |
Set focus to the first focusable checkbox in the checkbox set. Disabled checkboxes are not focusable. If hints, help Instruction or messages exist in a note window, pop up the note window. |
Checkbox |
Space |
Toggles the checkbox; If the checkbox is unselected, it will select it and vice versa. |
Checkbox |
Tab |
Sets focus to the next focusable checkbox in the checkbox set. Disabled checkboxes are not focusable. If the target is the last focusable checkbox in the checkbox set, focus goes to the next focusable item after the oj-checkboxset. |
Checkbox |
Shift+Tab |
Sets focus to the previous focusable checkbox in the checkbox set. Disabled checkboxes are not focusable. If the target is the first focusable checkbox in the checkbox set, focus goes to the previous focusable item before the oj-checkboxset. |
The Menus keystroke is used for all button menus. For example, the user menu on the landing page, tile menu in applications, and so on.
Target |
Key |
Action |
Menu Item |
Enter or Space |
Invoke the focused menu item's action. |
UpArrow |
Move focus to the previous menu item, wrapping around at the top. |
DownArrow |
Move focus to the next menu item, wrapping around at the bottom. |
Home |
Move focus to the first menu item. |
End |
Move focus to the last menu item. |
Menu Item in Top-level Menu |
Esc |
Close the menu and move focus to the launcher. |
JET Component or HTML Element having a JET Context Menu |
Shift + F10 |
Open the context menu. |
This section contains information on the Control Specific Help component.
Target |
Key |
Action |
Control Specific Help |
Tab |
Set focus to the Help button and reads the context Help text. |
This section contains information on the date or DateTime keystroke.
Target |
Key |
Action |
Input element |
DownArrow or UpArrow |
Shows the calendar grid and moves the focus into the expanded grid. |
Input element |
Esc |
Close the grid. |
Input element |
Tab In |
Set focus to the input. If hints, titles, or messages exist in a note window, pop up the note window. |
Picker |
Enter |
Select the currently focused day |
Picker |
UpArrow |
Move up in the grid. |
Picker |
DownArrow |
Move down in the grid. |
Picker |
RightArrow |
Move right in the grid. |
Picker |
LeftArrow |
Move left in the grid. |
Picker |
Esc |
Close the grid. |
Picker |
Home |
Move focus to first day of the month. |
Picker |
End |
Move focus to last day of the month. |
Picker |
Page Up |
Switch to previous month. |
Picker |
Page Down |
Switch to next month. |
Picker |
Alt + Page Up |
Switch to previous year. |
Picker |
Alt + Page Down |
Switch to next year. |
Picker |
Ctrl + Alt + Page Up |
Switch to previous by stepBigMonths. |
Picker |
Ctrl + Alt + Page Down |
Switch to next by stepBigMonths. |
Picker |
Ctrl + Alt + T |
Places focus on the Today button if it exists. |
Target |
Key |
Action |
Input element |
When not in Inline Mode, shows the calendar grid and moves the focus into the expanded grid. When in Inline Mode, shows the time picker and moves the focus into the expanded time picker. |
Input element |
Shift + DownArrow or UpArrow |
Shows the time picker and moves the focus into the expanded time picker. |
Input element |
Esc |
Close the grid. |
Input Element |
Tab In |
Picker |
Enter |
Select the currently focused day. |
Picker |
UpArrow |
Picker |
DownArrow |
Picker |
RightArrow |
Picker |
LeftArrow |
Picker |
Esc |
Close the grid. |
Picker |
Home |
Move focus to the first day of the month. |
Picker |
End |
Move focus to the last day of the month. |
Picker |
Page Up |
Switch to the previous month. |
Picker |
Page Down |
Picker |
Alt + Page Up |
Switch to the previous year. |
Picker |
Alt + Page Down |
Picker |
Picker |
Ctrl + Alt + PageDown |
Picker |
Ctrl + Alt + T |
This section contains information on the dialog keystrokes.
Target |
Key |
Action |
Dialog |
Esc |
Close the dialog. |
Dialog Close Icon |
Enter or Space |
Close the dialog. |
This section contains information on the Expand Collapse component.
Target |
Key |
Action |
Header |
Space or Enter |
This section contains information on the Expression Builder component.
Target |
Key |
Action |
Expression Shuttle Tree |
Tab |
Set focus to the Tree |
Tree |
See Hcy Br Tree(oj-tree) for the Keystrokes |
Expression Textbox |
Tab |
Set focus to the TextArea |
This section contains information on the OJET Expression Builder Launcher component.
Target |
Key |
Action |
Launch Button |
Tab |
Set focus to the Launch Button |
Launch Button |
Enter |
Activates the control and opens the Popup Window |
Menu Drop-down |
Tab |
Set focus to the Menu Item |
Menu Drop-down |
Enter |
Activates the selected Menu Item and refreshes the Grid with the updated state |
This section contains information on the Foldable Layout keystrokes.
Target |
Key |
Action |
Foldable layout |
Left Arrow |
Moves to previous panel |
Foldable layout |
Right Arrow |
Moves to next panel |
Foldable layout |
F2 |
To navigate between focusable elements inside the panel |
This section contains information on the grid keystroke.
Target |
Key |
Action |
Cell |
Tab |
The first Tab into the DataGrid moves focus to the first cell of the first row. The second Tab moves focus to the next focusable element outside of the DataGrid. |
Shift + Tab |
The first Shift + Tab into the DataGrid moves focus to the first cell of the first row. The second Shift + Tab moves focus to the previous focusable element outside of the DataGrid. |
LeftArrow |
Moves focus to the cell of the previous column within the current row. There is no wrapping at the beginning or end of the columns. If a row header is present, then the row header next to the first column of the current row will gain focus. |
RightArrow |
Moves focus to the cell of the next column within the current row. There is no wrapping at the beginning or end of the columns. |
UpArrow |
Moves focus to the cell of the previous row within the current column. There is no wrapping at the beginning or end of the rows. If a column header is present, then the column header above the first row of the current column will gain focus. |
DownArrow |
Moves focus to the cell of the next row within the current column. There is no wrapping at the beginning or end of the rows. |
Home |
Moves focus to the first (available) cell of the current row. |
End |
Moves focus to the last (available) cell of the current row. |
Page Up |
Moves focus to the first (available) cell in the current column. |
Page Down |
Moves focus to the last (available) cell in the current column. |
Ctrl + Space |
Selects all the cells of the current column. This is only available if multiple cell selection modes are enabled. |
Shift + Space |
Selects all the cells of the current row. This is only available if multiple cell selection modes are enabled. |
Shift + Arrow |
Extends the current selection. |
Ctrl + Arrow |
Move focus to level 0 of the active index of the header in the arrow direction if it exists. |
Shift + F8 |
Freezes the current selection, therefore allowing the user to move focus to another location to add additional cells to the current selection. This is used to accomplish non-contiguous selection. Use the Esc key or press Shift+F8 again to exit this mode. |
Shift + F10 |
Brings up the context menu. |
Ctrl + X |
Marks the current row to move if dnd is enabled and the data source supports move operation. |
Ctrl + V |
Move the row that is marked to directly under the current row. If the row with the focused cell is the last, then it is a move to the row above the current row. |
Ctrl + A |
If multiple selections are enabled, perform a select all on the Datagrid. |
Ctrl + Alt + 5 |
Read the context and content of the current cell to the screen reader. |
F2 |
Makes the content of the cell actionable, such as a link. |
Enter |
Makes the content of the cell actionable and acts on the content, such as going to a link. |
Alt + Enter |
Esc |
If the cell is actionable, it exits the actionable mode. |
Column Header Cell |
LeftArrow |
Moves focus to the previous column header. There is no wrapping at the beginning or end of the column headers. |
RightArrow |
Moves focus to the next column header. There is no wrapping at the beginning or end of the column headers. |
DownArrow |
Moves focus to the cell of the first row directly below the column header. If using nested headers moves to focus up a level. |
UpArrow |
If using nested headers moves the focus down a level. |
Ctrl + UpArrow |
If in the column end header, move focus to level 0 of the active index in the column header if it exists. |
Ctrl + DownArrow |
If in the column header, move focus to level 0 of the active index in the column end header if it exists. |
Enter |
Toggle the sort order of the column if the column is sortable. |
Shift + F10 |
Space |
If multiple selections are enabled and not in the selection Mode row, the column(s) underneath the header will be selected. |
If multiple selections are enabled and not in the SelectionMode row, the column selection extends to the right by the number of columns covered by the header to the right of the current selection frontier header. |
Shift + LeftArrow |
If multiple selections are enabled and not in the SelectionMode row, the column selection extends to the right-left the number of columns covered by the header to the left of the current selection frontier header. |
Shift + UpArrow |
enabled and not in the SelectionMode row and the current
selection frontier header has a parent nested header, the column
selection extends to cover the columns beneath the parent header. |
Shift + DownArrow |
selection frontier header has a child nested header, the column
selection extends to cover the columns beneath the child header. |
Row Header Cell |
UpArrow |
Moves focus to the previous row header. There is no wrapping at the beginning or end of the row headers. |
DownArrow |
Moves focus to the next row header. There is no wrapping at the beginning or end of the row headers. |
RightArrow |
Moves focus to the cell of the first column directly next to the row header. If using nested headers moves to focus up a level. |
LeftArrow |
Moves focus to the cell of the first column directly next to the row header in the RTL direction. If using nested headers moves the focus down a level. |
Ctrl + LeftArrow |
If in the row end header, move focus to level 0 of the active index in the row header if it exists. |
Ctrl + RightArrow |
If in the row header, move focus to level 0 of the active index in the row end header if it exists. |
Shift + F10 |
Space |
If multiple selections are enabled, the row(s) underneath the header are selected. |
Shift + UpArrow |
If multiple selections are enabled, the row selection extends up by the number of rows covered by the header above the current selection frontier header. |
Shift + DownArrow |
If multiple selections are enabled, the row selection extends down by the number of rows covered by the header below the current selection frontier header. |
Shift + LeftArrow |
enabled and the current selection frontier header has a parent
nested header, the row selection extends to cover the rows beneath
enabled and the current selection frontier header has a child
the child header. |
This section contains information on the OJET Tree keystrokes.
Key |
Action |
UpArrow/DownArrow |
Moves between visible nodes. |
LeftArrow |
On an expanded node, collapses the node. |
RightArrow |
On a collapsed node, expands the node. |
Spacebar |
Toggles the selected status of the node. |
Home |
Moves to the top node of the tree. |
End |
Moves to the last visible node of the tree. |
Shift + UpArrow |
Extends selection up one node (assuming multiple selection has been defined). |
Shift + DownArrow |
Extends selection down one node (assuming multiple selection has been defined). |
Shift + Home |
Extends selection up to the top-most node. |
Shift + PageDown |
Extends selection to the last node. |
Ctrl + Spacebar |
Toggles the selection state of the current node (assuming multiple selection has been defined). |
Shift + Spacebar |
Extends selection to the current node (assuming multiple selection has been defined). |
Shift + F10 |
Invoke Context Menu (if defined) on current node. |
* (asterisk) |
Expands all nodes. |
This section contains information on the Hierarchy Browser Map component.
Target |
Key |
Action |
Hierarchy Browser Map |
Tab |
Set focus to the elements |
Select |
See Select-single (oj-single-select) for the keystrokes |
Tabs |
See Tabs(oj-tabs) for the Keystrokes. |
Tree |
See Hcy Br Tree (oj-tree) for the keystrokes. |
Buttons (Map, Automap, Unmap, Unmap All, Transform Map) |
Tab |
Set focus to the Buttons |
Enter |
Activates the Buttons |
This section contains information on the OJET Hierarchy Browser Shuttle component.
Target |
Key |
Action |
Hcy Browser controls |
Tab |
Set focus to the Hcy Browser controls |
Enter |
Activates the controls |
Tree |
See Hcy Br Tree(oj-tree) for the Keystrokes. |
Tabs |
See Tabs(oj-Tabs) for the Keystrokes. |
Button Menu |
See Context Menu(oj-menu) for the Keystrokes. |
This section contains information on the number keystroke.
Target |
Key |
Action |
Input |
Enter or Tab |
Submit the value you typed in the input field. |
Input |
Tab In |
Set focus to input. If hints, help, instruction, or messages exist in a note window, pop up the note window. |
Input |
UpArrow |
Increment the number. |
Input |
DownArrow |
Decrement the number. |
This section contains information on the Legend Component keystrokes.
Target |
Key |
Tab |
Shift + Tab |
UpArrow |
Move focus to previous item. |
DownArrow |
Move focus to next item. |
LeftArrow |
Move focus to previous item (on left). |
RightArrow |
Move focus to next item (on right). |
Enter |
Hides or unhides the data associated with the current item. |
This section contains information on the list view keystroke.
Target |
Key |
Action |
List Item |
F2 |
Enters Actionable Mode. This enables keyboard action on elements inside the item, including navigating between focusable elements inside the item. |
Esc |
Exits Actionable Mode. |
Tab |
When in Actionable Mode, navigates to the next focusable element within the item. If the last focusable element is reached, shift focus back to the first focusable element. When not in Actionable Mode, navigates to the next focusable element on the page (outside ListView). |
Shift+Tab |
When in Actionable Mode, navigates to the previous focusable element within the item. If the first focusable element is reached, shift focus back to the last focusable element. When not in Actionable Mode, navigates to the previous focusable element on the page (outside ListView). |
DownArrow |
Move focus to the item below. |
UpArrow |
Move focus to the item above. |
LeftArrow |
When display in card layout, move focus to the item on the left. |
RightArrow |
When display in card layout, move focus to the item on the right. |
Shift+DownArrow |
Extend the selection to the item below. |
Shift+UpArrow |
Extend the selection to the item above. |
Shift+LeftArrow |
When display in card layout, extend the selection to the item on the left. |
Shift+RightArrow |
When display in card layout, extend the selection to the item on the right. |
Shift+F10 |
Launch the context menu if there is one associated with the current item. |
Enter |
Selects the current item. Not applicable if the item is already selected. |
Space |
Toggles to select and deselect the current item. If previous items have been selected, deselects them and selects the current item. |
Shift+Space |
Selects contiguous items from the last selected item to the current item. |
Ctrl+Space |
Toggles to select and deselect the current item while maintaining previously selected items. |
Ctrl+X |
Marks the selected items to move if dnd.reorder is enabled. |
Ctrl+C |
Marks the selected items to copy if dnd.reorder is enabled. |
Ctrl+V |
Paste the items that are marked directly before the current item (or as the last item if the current item is a folder). |
Group Item |
LeftArrow |
Collapse the current item if it is expanded and is collapsible. For non-hierarchical data, do nothing. |
RightArrow |
Expand the current item if it has children and is expandable. For non-hierarchical data, do nothing. |
This section contains information on the messages keystrokes.
Target |
Key |
Action |
Focus within Messages |
Tab or Shift + Tab |
Navigate the content of the messages region. |
F6 |
Moves focus back to the last focused element outside the messages region. |
Esc |
Focus outside Messages |
F6 |
Move focus to the first message within the more recently disclosed messages region. |
This section contains information on the Metadata Browser Breadcrumb keystrokes.
Target |
Key |
Action |
Object Node |
Enter |
Expands dependencies and usage relationships for the selected item |
Object Node |
Shift + F10 |
Opens context menu |
Object Node |
F2 |
The OFSAA landing page uses the Navigation menu for the Left-Hand-Side (LHS) menu. The application selection menu is used to select an Application, Reports, Admin menu, and so on.
Target |
Key |
Action |
List Item |
Enter or Space |
Selects list item. |
List Item |
UpArrow |
Moves focus to the previous visible list item. |
List Item |
DownArrow |
Moves focus to the next visible list item. |
List Item |
For the horizontal navigation list, the focus is moved to the next visible item. |
List Item |
LeftArrow (RightArrow in right to left (RTL) |
For the horizontal navigation list, the focus is moved to the previous visible item. |
List Item |
Home |
Moves focus to the first visible list item. |
List Item |
End |
Moves focus to the last visible list item. |
List Item |
F2 |
If the focus is on a list item, pressing F2 makes its contents accessible using TAB. |
List Item |
Esc |
When F2 mode is enabled, press Esc to exit F2 mode. |
List Item |
Shift+Tab |
Move focus to the hierarchical menu button. Only applicable for sliding navigation list and when the hierarchical menu button is enabled. |
Group Item |
If the focus is on the collapsed node, expand the sublist. |
Group Item |
LeftArrow (RightArrow in RTL) |
If the focus is on the expanded node, collapses the sublist. |
List Item in the sublist |
Esc |
Applicable only for sliding navigation list. If focus is in a sublist, closes the sublist and moves focus to the parent list item. |
Hierarchical Menu button |
Enter |
NOTE: This target is visible only for the Sliding Navigation List. |
Tab |
Moves focus to the current list item. Note: This target is visible only for the Sliding Navigation List. |
Shift + Tab |
Moves focus to the Previous Icon. Note: This target is visible only for the Sliding Navigation List. |
Overflow Menu button |
Enter or Space |
NOTE: This is applicable only for the Horizontal Navigation List when overflow is set to popup. |
Previous Icon or List Header |
Enter |
Collapses
the sublist and slides to the parent list. |
Tab |
Moves
focus to Hierarchical Menu button. |
This section contains information on the Object Migration Canvas keystrokes.
Target |
Key |
Canvas Diagram |
This section contains information on the Object Node keystrokes.
Target |
Key |
Action |
Object Node |
Enter |
Object Node |
Shift + F10 |
Object Node |
F2 |
This section contains information on the Password keystroke.
Target |
Key |
Action |
Input element |
Tab In |
Set focus to the input. If hints, help, instruction, or messages exist in a note window, pop up the note window. |
This section contains information on the popup keystrokes.
Target |
Key |
Action |
Focus within Popup |
Navigate the content of the popup. Close the open popup if there are no tab stops in the popup. |
F6 |
Move focus to the launcher for a popup with modeless modality. Close the open popup if the modality is modal. |
Esc |
Close the open popup. |
Popup Launcher |
F6 |
Move focus to the first tab stop within the open popup. If there is not a tab stop within the content, the focus is established on the popup. |
This section contains information on the Radio keystroke.
Target |
Key |
Action |
Input |
UpArrow |
Select the previous input in the group. |
Input |
DownArrow |
Select the next input in the group. |
Radioset |
Tab In |
Set focus to the checked radio input. If hints, titles, or messages exist in a note window, pop up the note window. |
This section contains information on the Search Box component.
Target |
Key |
Action |
Input field |
Enter |
Set the input text as the value. |
Input field |
If the drop down is not open, expand the drop down list. |
Input field |
Esc |
Collapse the drop down list. If the drop down is already closed, do nothing. |
Input field |
Tab In |
Set focus to the Input Search. |
This section contains information on the Multiselect keystroke.
Target |
Key |
Action |
Option item |
Enter |
Select the highlighted choice from the drop-down list. |
Drop down |
Highlight the option item in the direction of the arrow. If the drop-down is not open, expand the drop-down list. |
Select box |
Move focus to the previous or next selected item. |
A selected item with remove icon |
Backspace or Delete |
Remove the selected item having focus. |
Drop down |
Esc |
Collapse the drop-down list. If the drop-down is already closed, do nothing. |
Select box or search box |
Any characters for the search term |
Filter down the results with the search term. |
Select |
Tab In |
Set focus to the select. If hints, titles, or messages exist in a note window, pop up the note window. |
This section contains information on the Select keystroke.
Target |
Key |
Action |
Option item |
Enter |
Select the highlighted choice from the drop down. |
Input field |
Enter |
Drop down |
Highlight the option item on the drop-down list in the direction of the arrow. If the drop down is not open, expand the drop-down list. |
Drop down |
Esc |
Collapse the drop-down list. If the drop down is already closed, do nothing. |
Select |
Tab In |
Set focus to the Select. If hints, title or messages exist in a notewindow, pop up the notewindow. |
This section contains information on the switch keystroke.
Target |
Key |
Action |
Switch Thumb |
Enter or Space |
Toggle switch value |
Switch Thumb |
Tab In |
Set focus to the thumb. If hints, titles, or messages exist in a note window, pop up the note window. |
This section contains information on the Table Component keystrokes.
Target |
Key |
Action |
Cell |
Tab |
The first Tab into the Table moves focus
to the first column header. The second Tab moves focus to the
next focusable element outside of the Table. |
Cell |
Shift+Tab |
The first Shift+Tab into the Table moves
focus to the first column header. The second Shift+Tab moves focus
to the previous focusable element outside of the Table. |
Cell |
DownArrow |
Move focus to the next row. |
Cell |
Shift+DownArrow |
Select and move focus to the next row. |
Cell |
UpArrow |
Move focus to the previous row. If at the first row then move to the column header. |
Cell |
Shift+UpArrow |
Select and move focus to the previous row. |
Cell |
LeftArrow |
Do nothing. |
Cell |
RightArrow |
Do nothing. |
Cell |
Home |
Move focus to first row. |
Cell |
End |
Move focus to last row. |
Cell |
Space |
Select row. |
Cell |
Enter |
If the table editMode is rowEdit
then make the current row editable. |
Cell |
F2 |
If the table editMode is none
then toggle the current row to actionable mode if there exists
a tabbable element in the row. Once toggled to actionable mode,
focus will be moved to be first tabbable element in the row. |
Cell in Editable Row |
Tab |
Move focus to next editable cell or focusable
Shift+Tab |
Move focus to previous editable cell or
focusable element in the row. |
DownArrow |
Handled in the editable cell. |
Shift+DownArrow |
UpArrow |
Shift+UpArrow |
LeftArrow |
RightArrow |
Handled by the editable cell. |
Home |
End |
Space |
Enter |
Make the next row editable and move focus
to the editable cell in current column in the next row. |
Shift+Enter |
Make the previous row editable and move
focus to the editable cell in current column in the previous row. |
F2 |
Toggle the current row between editable and readonly. |
Esc |
Make the current row readonly. |
Column Header |
Tab |
Navigate to next focusable element on page (outside table). |
Column Header |
Shift+Tab |
Navigate to previous focusable element on page (outside table). |
Column Header |
DownArrow |
Move focus to the first row. |
Column Header |
UpArrow |
Do nothing. |
Column Header |
LeftArrow |
Move focus to previous column header. |
Column Header |
Shift+LeftArrow |
Select and move focus to previous column header. |
Column Header |
RightArrow |
Move focus to next column header. |
Column Header |
Shift+RightArrow |
Select and move focus to next column header. |
Column Header |
Home |
Move focus to first column header. |
Column Header |
End |
Move focus to last column header. |
Column Header |
Space |
Select column. |
This section contains information on the tabs keystrokes.
Target |
Key |
Action |
List Item |
Enter or Space |
Up Arrow |
Down Arrow |
Moves focus to the next visible list item |
Right Arrow (Left Arrow in RTL) |
For the horizontal tab bar, the focus is moved to the next visible item. |
Left Arrow (Right Arrow in RTL) |
For the horizontal tab bar, the focus is moved to the previous visible item. |
Home |
End |
F2 |
Esc |
Ctrl+X |
Marks the current item to move if reorderable is enabled. |
Ctrl+V |
Paste the item that is marked directly before the current item. |
DELETE |
Delete the current item. |
Enter or Space |
Open menu. See menu button keystrokes for details. NOTE: This is applicable only for Horizontal Tab Bar when overflow is set to popup. |
This section contains information on the textarea keystroke.
Target |
Key |
Action |
TextArea |
Tab In |
Set focus to the textarea. If hints, help, instruction, or messages exist in a note window, pop up the note window. |
This section contains information on the textbox keystroke.
Target |
Key |
Action |
Input |
Tab In |
This section contains information on the tree keystrokes.
Target |
Key |
Action |
Item |
Tab |
Navigates to the next focusable element on-page. |
Shift+Tab |
Navigates to the previous focusable element on-page. |
DownArrow |
Moves focus on the item below. |
UpArrow |
Moves focus on the item above. |
LeftArrow |
On an expanded item, collapses the item. Otherwise, move focus to the item above. The action is swapped with RightArrow in RTL locales. |
RightArrow |
On a collapsed item, expands the item. Otherwise, move focus to the item below. The action is swapped with LeftArrow in RTL locales. |
Shift+DownArrow |
Extends the selection to the item below. Only applicable if multiple selections are enabled. |
Shift+UpArrow |
Extends the selection to the item above. Only applicable if multiple selections are enabled. |
Space |
Toggles the selection of the current item and deselects the other items. |
Enter |
Selects the current item and deselects the other items. No-op if the current item is already selected. |
Ctrl+Space/Enter |
Toggles the selection of the current item while maintaining previously selected items. Only applicable if multiple selections are enabled. |
Shift+Space/Enter |
Selects contiguous items from the last selected item to the current item. Only applicable if multiple selections are enabled. |
This section contains information on the OJET Tree View keystrokes.
Target |
Key |
Action |
Item |
Tab |
Navigates to next focusable element on page. |
Item |
Shift+Tab |
Navigates to previous focusable element on page. |
Item |
DownArrow |
Moves focus to the item below. |
Item |
UpArrow |
Moves focus to the item above. |
Item |
LeftArrow |
Item |
RightArrow |
Item |
Shift+DownArrow |
Extends the selection to the item below. Only applicable if the multiple selection is enabled. |
Item |
Shift+UpArrow |
Extends the selection to the item above. Only applicable if the multiple selection is enabled. |
Item |
Space |
Item |
Enter |
Selects the current item and deselects the other items. No op if the current item is already selected. |
Item |
Ctrl+Space/Enter / CMD+Space/Enter |
Toggles the selection of the current item while maintaining previously selected items. Only applicable if the multiple selection is enabled. |
Item |
Shift+Space/Enter |
Selects contiguous items from the last selected item to the current item. Only applicable if the multiple selection is enabled. |
Ctrl+A / CMD+A |
If selection Mode is multiple, will select all selectable nodes. |
