Use the Search and List page to filter the list of reports that you want to open, view, analyze, and/or take action.
The types of search supported are: Views, Basic Search, and Advanced Search. The Reports List section displays the list of reports you have specified in the search parameters. Use the Search and List page to perform the following search activities and view the results:
· Basic Search: This search is based on a limited set of search fields, such as Report Number, Report Status, and Report Name. This is the default search option.
· Advanced Search: This search is based on the ability to specify an additional set of fields to narrow down your search results.
· Views: This search helps you to quickly filter the reports based on pre-defined search queries. Select the search criteria from the Views option and filter the list of reports.
· Saving Views: Use this option to save your search criteria as a View. The saved views are available in the Views drop-down list.
· Regulatory Reports List: This is the list of reports that matches the search criteria provided.
This search is based on a limited set of search criteria and helps retrieve the required reports for your analysis. This search type is very useful if you know the report details such as report name, report number and so on. Only those reports that match the criteria you specify are displayed.
To search for reports using basic search criteria, follow these steps:
1. Go to the Search and List page. By default, the Basic Search option is displayed.
2. Enter the required fields as described in Table 5.
3. Click Search. Report (s) matching your search criteria are displayed.
The Advanced Search offers an additional set of fields to the search fields provided with the Basic Search. This option helps you narrow down your search results. You can use combinations of these search criteria to quickly find the reports you are looking for.
To search for reports using advanced search criteria, follow these steps:
1. On the Search and List page, click Advanced Search. The Advanced Search window is displayed.
2. Enter the required fields as described in Table 5 .
3. Click Go. The reports matching your search criteria are displayed on the Search and List page.
To perform a different search, click the Reset button and enter your search criteria again.
Views search helps you quickly filter the reports based on pre-defined search queries. You can save your search criteria as Views. For more information on pre-defining the search as views, see Saving Views .
To search reports using Views option, follow these steps:
1. On the Search and List page, click Views to view the available options.
2. Select the out of box pre-defined views as described in Table 6. The Search and List page refreshes to show the results matching the View search criteria.
You can also create your pre-defined views. For more information, see Saving Views .
Views |
Description |
Open/ Reopened/Rework - Reports Last Modified by Me |
Select this option to view the list of reports in the Open, Reopened, or Rework status which you have modified in the last session. NOTE: This is the default view for an Analyst. |
Reports Awaiting Approval |
Select this option to view the list of reports in Requested for Approval status. NOTE: This is the default view for a Supervisor. |
Reports Overdue |
Select this option to view the list of reports that have exceeded their due dates. When a report has passed its due date or when the due date is the same as the system date, the reports in the list are highlighted in Red. |
Reports Submitted in Last 3 Months |
Select this option to view the list of reports that were submitted in the last three months. |
All Views saved by the user |
Select Views that you have created and saved using the Save as View option. For more information, see Saving Views . |
Use Save as View option to save your search criteria as a View. The saved views are available in the Views drop-down list. For more information, see Views .
For example, if you regularly search for reports approved by Supervisor1 and reports approved on or before December 2019, you can pre-define a search as SupDecember under Views. When you login to the application next time, rather than re-entering search criteria, you select the required pre-defined view as SupDecember and filter the reports.
To save your search criteria as a view, follow these steps:
1. On the Search and List page, click the Advanced Search. The Advanced Search window is displayed.
2. Enter the search criteria in the search fields. For more information on the search criteria, see Table 5 .
3. Click Save as View. The Save as View window is displayed.
4. Enter the view name and view details. The field marked with * an asterisk is mandatory.
NOTE |
The View Details field allows a maximum of 255 characters. |
5. Click Save to add a new pre-defined view.
6. Click OK. The view is saved and displayed in the Views drop-down list.
NOTE |
The saved view is available only to the user who has created it, not to other users. |
Use the Regulatory Reports List section to view the list of reports based on your search criteria. Click the required report number to view additional information of reports that you can use to analyze or take actions. By default, all reports are displayed if you do not use any search criteria to filter the list.
NOTE |
If the report is already opened by another user, then that report is locked. You can only view that report. |
Use the Regulatory Reports list section to perform the following tasks:
· Select the required report(s) to take actions such as Set Due Date, Cancel Filing, Export to Excel, and so on.
· Click the report number to view details pertaining to the report in the Report Details page.
· Sort list of values in the column by using Sort Ascending, Sort Descending, and Clear the sort options. Right-click on the column and select the required sort option to view the list.
· View column headers (Report Name, Created Date, Due date, and so on) of your choice by using the Field Chooser option. Right-click on the column and select the required columns header names and the size of the column from the Field Chooser list to view.
· Navigate pages using the Pagination option. Enter the page number or use arrows to navigate to and fro.
· In the Due Date column, dates in green will expire in few days. Dates in yellow indicate that due date is nearing, and dates in red indicate that the due date has expired.
