8 Filing a Report
An authorized user can generate an E-File for
approved reports. The generated E-File is submitted with the FIU-IND
E-Filing System. The E-File is validated by FIU-IND and an acknowledgment
(.asc file) is generated. The acknowledgment file is uploaded into the
OFS CRR application. The application will then associate the FIU-IND returned
Identifier to each STR within the e-file. Now, the user can then mark
the STR process as complete.
· Opening
an Approved Report : Use this
section to search and access the specific approved reports. Click the
required Report
Number on
the Approved
Regulatory Reports List page
and the Approved
Report Details page is
opened.
· Generating E-File :
Use this section to generate an e-file for all approved report(s).
· Submitting an E-File :
Use this section to submit an e-file into FIU-IND’s E-Filing System.
· Uploading Acknowledgment :
Use this section to upload an acknowledgment for the submitted E-Files.
· Generating
a Batch: Use this section to
generate a revised
batch/e file and submit to the regulator.
Opening
an Approved Report
To open the Approved Report page, follow these steps:
1. On
the Navigation List LHS menu,
hover over India STR and click
File Report. The File
Report page is displayed with Approved
Reports Search and List as default section.
2. Enter
the required fields as described in Table 21 .
Table 21: Approved
Reports Search
Fields |
Description |
Report Number |
Enter one or more report numbers
you want to view. For multiple report numbers, separate the report
numbers with a comma. Ensure you don't enter a space after the
comma. Report Numbers are not case-sensitive. This overrides all
other filter criteria. For example, 660,671.
NOTE:
You can enter a maximum
of 50 characters in this field. |
Report Name |
Enter the report name you want
to view.
This field supports a wildcard search.
You can use ‘%’ and ‘_’ as wildcard indicators.
NOTE:
Type of Report |
Select one or more report types
from the following options.
· Replacement
· Delete
· New |
Reporting Entity
Name |
Select a reporting entity name.
Principal Officer’s
Name |
Select the principal officer’s
name. |
Jurisdiction |
Select the jurisdiction to view
reports mapped to the selected jurisdiction. Jurisdictions are
defined by your institution.
Every report is associated with
a jurisdiction. When a report is created from a case, the report
inherits the jurisdiction that was associated with that case.
Each user has access to a set of
jurisdictions. Every report is associated with a single jurisdiction.
A user has access to any report where the user's jurisdictions
intersect with the report’s jurisdiction. |
Account Number(s) |
Enter account (s) involved in
the suspicious activity report.
You can enter multiple account numbers
by using a comma to separate the values. |
Original E-file
ID |
Enter the unique identification
number of the original e-file. |
Case ID |
Enter the case ID to view reports
associated with the specific case ID. For multiple case IDs, separate
them with a comma. Ensure you don't enter a space after the comma.
This overrides all other filter criteria. For example, CA660,ca671.
NOTE:
This search is not case-sensitive.
You can enter a maximum of 255 characters in this field.
Case ID is the identifier that has
triggered the creation of a report in the Compliance Regulatory
Reporting application. |
Created By |
Select the user who has created
the report.
You can enter multiple names by
Created Date >= |
Select the created date to view
reports having a created date greater than or equal to the specified
date. Using this criterion, you can view the reports that were
created during the particular date range. For example, reports
created on or after December 26, 2019.
NOTE:
You can either perform a
range search using ‘Created Date >=’ and ‘Created <=’ or
use them independently. |
Created Date <= |
reports having a created date lesser than or equal to the specified
created on or before December 26, 2019. |
Approved By |
Select the name of an approver
who approved reports. For example, Supervisor1, Supervisor2, and
so on. |
Approved Date >= |
Select the approved date to view
reports having an approved date greater than or equal to the specified
approved during the particular date range. For example, reports
approved on or after December 26, 2019. |
Approved Date <= |
reports having an approved date lesser than or equal to the specified
date. Using this criterion, you can view the reports that are
approved on or before December 26, 2019. |
Due Date>= |
Select the due date to view reports
having a due date greater than or equal to the specified date.
Using this criterion, you can view the reports that have a due
date during the particular date range. For example, reports having
a due date on or after December 26, 2019. |
Due Date<= |
having a due date lesser than or equal to the specified date.
a due date on or before December 26, 2019. |
3. Fields
marked with * asterisk are mandatory.
4. Click
Go. The approved reports matching
your search criteria are displayed on the Search
and List page.
To
carry out a different search, click the Reset button
and enter your search criteria again.
Use the Approved Reports List section to view the
list of approved reports based on your search criteria. Click the required
report number to view additional information of reports that you can use
to analyze or take actions. By default, all approved reports are displayed
if you do not use any search criteria to filter the list.
NOTE |
If
the approved report is already opened by another user, then that
report is locked. You can only view that report. |
Generating
E-File
Use the Approved
Report tab to generate an e-file for all approved report(s)
and upload the resultant .txt file
NOTE |
When
an e-file is generated, an attachment zip file is created for
the e-file with a .csv file
in it. This .zip file
is only available if attachments were associated with any STR
within the E-File. |
To generate an e-file, follow these steps:
1. On
List, select the report(s) to generate e-file.
2. Click
Generate E-File. The Generate
E-File window is displayed.
3. Enter
the reason for revision, if any, and the required comments.
4. Click
Save to confirm the e-file
generation. The status of the report changes to E-File
Generated. The reports on which e-files are
generated are moved from the Approved
Reports list to E-File List.
NOTE |
· If the approved report is already
opened by another user, then that report is locked. You can only
view that report.
· You
can not e-file an approved report that is already generated or
rejected. |
5. For
more information, see Submitting an E-File .
Submitting
an E-File
Use the E-File
Status tab to submit the generated e-files into FIU-IND’s
E-Filing System.
To submit an E-File, follow these steps:
1. On
the File Report page, click
the E-File tab. The E-File page
is displayed with Search and List as
a default section.
2. Enter
the required fields as described in Table 22 .
Table 22: E-File
Search
Fields |
Description |
E-file Number |
Enter the e-file number. |
E-file Status |
Select the status of the e-file: Select
All, E-File Generated, or Submitted. |
Type of Report |
Select the type of report: New, Corrected,
Delete, Corrected, and Deleted. |
E-File Generated By |
Select the user (s) who generated e-files.
E-File Generated >= |
Select the e-files generated date to view
e-files having generated date greater than or equal to the specified
date. Using this criterion, you can view the e-files that were
generated during the particular date range. For example, e-files
generated on or after December 26, 2019. |
E-File Generated <= |
e-files having generated date lesser than or equal to the specified
generated on or before December 26, 2019. |
Report Number |
Enter the regulatory report number for which
the e-file is generated. Wildcard searches are supported using
% as the wildcard symbol. |
Report Name |
Enter the name of the regulatory report
for which the e-file is generated. Wildcard searches are supported
using % as the wildcard symbol. |
Jurisdiction |
Select the jurisdiction (s) for which e-files
are generated. For example, JAPAC, AMEA, CA, and so on. |
Account Number |
Enter the account numbers that associated
with the approved report.
Case ID |
Enter the case ID of the report. |
3. Fields
4. Click
Go. The E-Files matching your
and List page.
To
NOTE |
If
the e-file is already opened by another user, then that e-file
is locked. You can only view that e-file. |
5. On
the E-File List, select the required
e-file (s) and click Submit. The
Submit E-File window is displayed
6. Select
the Check here to apply a single comment
to all included E-File to enter a single comment for all the
selected e-files.
Or,
select the e-file (s) from the list and enter respective comments (if
you want to provide different comments for each e-files).
7. Click
Save. The status of the E-file
changes to Submitted in the E-File list page.
Uploading
Acknowledgment
To upload an acknowledgment for e-files, follow
these steps:
1. On
e-file(s) in the Submitted status
and click Upload Acknowledgment.
The Upload Acknowledgment window
is displayed
2. Enter
the logical file name.
3. Select
the file to upload. The file can be selected from the system by using
the Browse option and click
Attach File.
4. Add
5. Click
Save to proceed with attachment.
· After
acknowledgment is uploaded, the system will read it and reflect details
in the Acknowledgment tab. For more information, see Generating
a Batch .
· If
the system is not able to read the acknowledgment file, then it throws
an error message as Invalid Acknowledgment
Format.
· In
the Acknowledgment tab,
it reflects all the acknowledgment details. For more information, see
Generating a Batch .
Generating
a Batch
A Batch is the collection of the E-Files that
are submitted to the FIU.
Use the Acknowledgment
tab to view the list of acknowledgment receipts that are uploaded through
the E-File status tab and
to generate the batch.
The Revised
E-File Generated is used to check whether a revised report
is generated on a selected acknowledgment ID. You can generate as many
revised batch/e-file on a selected acknowledgment ID, till it is submitted
to the regulator. When you try to generate revised E-File, a list shows
only those reports which are not revised.
To generate a batch, follow these steps:
1. On
the Acknowledgments tab.
The Acknowledgment page displays Acknowledgment
receipts Search and List as a default section.
2. Enter
the required fields as described in Table 23 .
Table 23: Acknowledgment
Search
Fields |
Description |
E-file Number |
Acknowledgment
Uploaded Date >= |
Select the acknowledgment upload date to
view acknowledgments having uploaded date greater than or equal
to the specified date. Using this criterion, you can view acknowledgments
that were uploaded during the particular date range. For example,
acknowledgments uploaded on or after December 26, 2019.
NOTE:
range search using ‘acknowledgment upload date>=’ and ‘acknowledgment
upload <=’ or use them independently. |
Acknowledgment
Uploaded Date <= |
view acknowledgments having uploaded date lesser than or equal
acknowledgments uploaded on or before December 26, 2019. |
3. Fields
4. Click
Go. The acknowledgments matching
and List page.
To
NOTE |
If
an acknowledgment ID is already opened by another user, then that
e-file is locked. You can only view that e-file. |
5. On
the Acknowledgment Receipt List, select
the required Acknowledgment (s) and click Generate
Revised Batch. The Generate Revised Batch window
is displayed
6. Select
the type of submission: Delete or
Replacement.
7. Enter
the relevant comments.
8. Click
Save. A batch is generated.
