39.17 About Host Compliance
Host compliance provides you information on the compliance frameworks, standards, and the targets that are associated with the compliance standard selected in the Compliance Standard Library.
Cloud Control displays the evaluation results and level of compliance of a target against a compliance framework. The Compliance Frameworks evaluation results provide an overview of the state of the framework, the level of compliance (Critical, Warning, or Compliant.) and the criticality of any violations (Critical, Warning, or Minor Warning.) You can view the average score, as a percentage, and the Author.
When Compliance Framework errors are detected, the following information is available:
  • Root Compliance Standard
  • Root Compliance Standard State
  • Parent Compliance Standard
  • Rule
  • Root Target Information
  • Target Information
  • Error Date
  • Error Message
39.17.1 Viewing Compliance Frameworks
The Compliance Framework tab displays the evaluation results and errors, if any.
  1. Click Hosts from the Targets menu.
  2. Click the target name to open the home page.
  3. Click Host in the upper left corner of the page. Click Compliance, then click Results.
  4. Click Compliance Frameworks to display the Evaluation Results tab.
  5. Click the Errors tab to see if there are any Compliance Framework errors.
39.17.2 Viewing Compliance Standards
You can search for a specific compliance standard for a host and view the evaluation results and errors.
  4. Click Compliance Standards to display the Evaluation Results tab.
39.17.3 Viewing Target Compliance
The Target Compliance table lists the targets that are associated with the compliance standard selected in the Compliance Standard Library.
  4. Click Target Compliance to display the targets that are in compliance with the standards.
