12 Oracle Coherence Cache
All Oracle Coherence entities are monitored from a central MBean (JMX) server or central Management Node. All metrics source are Coherence MBeans and Java platform MBeans. Sample Coherence MBean reference available from the "Coherence MBean Reference" appendix in the Oracle Coherence Management Guide:
http://docs.oracle.com/cd/E24290_01/coh.371/e22842/appendix_mbean.htm
General Metric Naming Conventions:
  • Total {Metric Name} - Absolute Total value as returned by MBean server. Typically this is since node start or since statistics were last reset. For example, Cache Usage > Total Gets metric for a Oracle Coherence Node target is the total number of gets on a cache since node start or statistics reset.
  • Total {Metric Name} Per Minute - Rate computed on Absolute Total value as discussed in "Per Minute metric computation"
  • Aggregate {Metric Name} - Aggregated value across multiple entities. For example Cache Usage > Aggregate Gets for a Oracle Coherence Cache target is the aggregate number of gets for a cache across all nodes that supports this cache
  • Aggregate {Metric Name} Per Minute - Rate computed on Aggregate value as discussed in "Per Minute metric computation"
  • Metric names without Total/Aggregate - These are either STRING metrics or instantaneous values as returned by MBean server. They may be aggregated across entities where applicable.
12.1 Response
This metric category shows the time required, in milliseconds, for the server to respond to requests.
12.1.1 Cache Status
This metric displays the coherence cache status.
Target Version Collection Frequency
All Versions
Every 60 Seconds
12.2 Aggregate Storage Manager Metrics
This metric category provides information about the Aggregate Storage Manager metrics.
12.2.1 Aggregate Events Dispatched
This metric displays the total number of events dispatched by the Storage Manager.
Target Version Evaluation and Collection Frequency Upload Frequency Default Warning Threshold Default Critical Threshold Alert Text
All Versions
Every 5 Minutes
After Every 3rd Collection
Not Defined
Not Defined
Aggregate events dispatched by Storage Manager is %value%
12.2.2 Aggregate Events Dispatched Per Minute
This metric displays the number of events dispatched per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate events dispatched per minute by Storage Manager is %value%.
12.2.3 Aggregate Evictions
This metric displays the number of evictions from the backing map managed by this Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate evictions by Storage Manager is %value%.
12.2.4 Aggregate Evictions Per Minute
This metric displays the number of evictions from the backing map per minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate evictions per minute by Storage Manager is %value%.
12.2.5 Aggregate Inserts
This metric displays the number of inserts into the backing map managed by this Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate inserts into backing map is %value%.
12.2.6 Aggregate Inserts Per Minute
This metric displays the number of inserts into backing map per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate inserts per minute into backing map is %value%.
12.2.7 Aggregate Listener Filters
This metric displays the number of filter-based listeners currently registered with the Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate listener filters registered by Storage Manager is %value%.
12.2.8 Aggregate Listener Keys
This metric displays the number of key-based listeners currently registered with the Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate listener keys registered with Storage Manager is %value%.
12.2.9 Aggregate Locks Granted
This metric displays the number of locks currently granted for the portion of the partitioned cache managed by the Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate locks granted by Storage Manager is %value%
12.2.10 Aggregate Locks Pending
This metric displays the number of pending lock requests for the portion of the partitioned cache managed by the Storage Manager.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate locks pending in Storage Manager is %value%.
12.2.11 Aggregate Removes
This metric displays the number of removes from the backing map caused by operations such as clear, remove or invoke.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate removes from backing map is %value%.
12.2.12 Aggregate Removes Per Minute
This metric displays the number of removes from backing map per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate removes per minute from backing map is %value%.
12.3 Aggregate Cache Usage Metrics (Coherence version 3.4)
This metric category provides information about the Aggregate Cache Usage metrics.
12.3.1 Aggregate Puts
This metric displays the aggregate number of puts.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Puts in cache is %value%.
12.3.2 Aggregate Puts Per Minute
This metric displays the number of puts per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Puts per minute in cache is %value%.
12.3.3 Aggregate Puts Time (ms) Per Minute
This metric displays the total number of ms spent on put() operations per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Puts Time (ms) per minute is %value%.
12.3.4 Aggregate Gets
This metric displays the aggregate number of gets.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Gets in cache is %value%.
12.3.5 Aggregate Gets Per Minute
This metric displays the number of gets per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Gets per minute in cache is %value%.
12.3.6 Aggregate Gets Time (ms) Per Minute
This metric displays the total number of ms spent on get() operations per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Gets Time (ms) per minute is %value%
12.3.7 Aggregate Hits
This metric displays the rough number of cache hits. A cache hit is a read operation invocation for which an entry exists in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Hits is %value%
12.3.8 Aggregate Hits Per Minute
This metric displays the rough number of cache hits per minute. A cache hit is a read operation invocation for which an entry exists in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Hits per minute is %value%
12.3.9 Aggregate Hits Time (ms) Per Minute
This metric displays the total number of ms per minute for the get() operations for which an entry existed in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Hits Time (ms) per minute is %value%
12.3.10 Aggregate Misses
This metric displays the rough number of cache misses. A cache miss is a read operation for which no entry exists in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Misses is %value%.
12.3.11 Aggregate Misses Per Minute
This metric displays the rough number of cache misses per minute. A cache miss is a read operation for which no entry exists in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Misses per minute is %value%.
12.3.12 Aggregate Misses Time (ms) Per Minute
This metric displays the total number of ms per minute for the get() operations for which no entry existed in this map.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Misses Time (ms) per minute is %value%
12.3.13 Aggregate Writes
This metric displays the total number of storage writes.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Writes is %value%
12.3.14 Aggregate Writes Per Minute
This metric displays the total number of storage writes per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Writes per minute is %value%.
12.3.15 Aggregate Write Time (ms) Per Minute
This metric displays the cumulative time spent on storage writes per minute.
All Versions
Every 15 Minutes
Not Defined
Not Defined
Aggregate cache Write Time (ms) per minute is %value%.
12.3.16 Aggregate Reads
This metric displays the total number of reads.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Reads is %value%.
12.3.17 Aggregate Reads Per Minute
This metric displays the total number of reads per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Reads per minute is %value%.
12.3.18 Aggregate Read Time (ms) Per Minute
This metric displays the cumulative time spent on reads per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Read Time (ms) per minute is %value%.
12.3.19 Aggregate Failures Per Minute
This metric displays the total number of storage failures per minute (load, store and erase operations).
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Failures per minute is %value%.
12.3.20 Aggregate Queue Size
This metric displays the size of the write-behind queue.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Queue Size is %value%.
12.3.21 Hit Probability
This metric displays the rough probability that the next invocation is a hit.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Cache Hit Probability is %value%.
12.3.22 Hits to Gets Ratio (%)
This metric displays the percentage ratio of cache hits to get() operation.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Cache Hits to Gets Ratio is %value%.
12.3.23 Average Time Per Get (ms)
This metric displays the average number of ms per get() invocation.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Get (ms) is %value%.
12.3.24 Average Time Per Get-Hit (ms)
This metric displays the average number of ms per get() invocation that is a hit.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Get-Hit (ms) is %value%
12.3.25 Average Time Per Get-Miss (ms)
This metric displays the average number of ms per get() invocation that is a miss.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Get-Miss (ms) is %value%.
12.3.26 Average Time Per Put (ms)
This metric displays the average number of ms per put() invocation.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Put (ms) is %value%.
12.3.27 Average Time Per Read (ms)
This metric displays the average time (in ms) spent per read operation.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Read (ms) is %value%.
12.3.28 Average Time Per Write (ms)
This metric displays the average time (in ms) spent per write operation.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Time per cache Write (ms) is %value%.
12.4 Aggregate Cache Usage Metrics (Coherence version 3.4.2 - 3.7.1)
This metric category provides information about the aggregate cache usage metrics for Coherence versions 3.4.2 - 3.7.1.
12.4.1 Aggregate Puts
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.2 Aggregate Puts Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.3 Aggregate Puts Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.4 Aggregate Gets
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.5 Aggregate Gets Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.6 Aggregate Gets Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.7 Aggregate Hits
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.8 Aggregate Hits Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.9 Aggregate Hits Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.10 Aggregate Misses
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.11 Aggregate Misses Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.12 Aggregate Misses Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.13 Aggregate Writes
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.14 Aggregate Writes Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.15 Aggregate Write Time (ms) Per Minute
All Versions
Every 15 Minutes
Not Defined
Not Defined
12.4.16 Aggregate Reads
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.17 Aggregate Reads Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.18 Aggregate Read Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.19 Aggregate Failures Per Minute
This metric displays the total number of storage failures per minute (load, store, and erase operations).
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.20 Aggregate Queue Size
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.21 Aggregate Prunes
This metric displays the total number of prunes. A prune operation occurs every time the cache reaches its high watermark.
12.4.22 Aggregate Prunes Per Minute
This metric displays the number of prune operations per minute. A prune operation occurs every time the cache reaches its high watermark.
12.4.23 Aggregate Prune Time (ms) Per Minute
This metric displays the total number of ms for the prune operations per minute.
12.4.24 Hit Probability
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.25 Hits to Gets Ratio (%)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.26 Average Time Per Get (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.27 Average Time Per Get-Hit (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.28 Average Time Per Get-Miss (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.29 Average Time Per Put (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.30 Average Time Per Read (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.4.31 Average Time Per Write (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.5 Aggregate Cache Size Metrics
This metric category provides information about the Aggregate Cache Size metrics.
12.5.1 Aggregate Units
This metric displays the size of the cache measured in units.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate cache Units is %value%.
12.5.2 Unit Factor
This metric displays the factor by which the Units, LowUnits, and HighUnits properties are adjusted.
All Versions
Every 5 Minutes
12.5.3 Aggregate Cache Objects
This metric displays the number of objects in the cache.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Cache Objects is %value%
12.5.4 Aggregate Memory Usage in Bytes (assuming BINARY Calculator)
This metric displays the number of bytes consumed by the objects in the cache.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Memory Usage is %value% bytes.
12.5.5 Aggregate Memory Usage in MB (assuming BINARY Calculator)
This metric displays the MB consumed by the objects in the cache.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Memory Usage is %value% MB
12.5.6 Average Object Size in Bytes
This metric displays the average memory consumed by each object in bytes.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Object Size is %value% bytes.
12.6 Aggregate Query Optimization Metrics (Coherence version 3.7)
This metric category provides information about the Aggregate Query Optimization metrics.
12.6.1 Maximum Query Duration (ms)
This metric displays the number of milliseconds of the longest running query.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Maximum Query Duration (ms) is %value%.
12.6.2 Aggregate Non Optimized Queries Executed Per Minute
This metric displays the total number of parallel queries that could not be resolved per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Non Optimized Queries Executed Per Minute is %value%.
12.6.3 Average Non Optimized Query Execution Time (ms)
This metric displays the average duration, in milliseconds, for non-optimized query execution.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Non Optimized Query Execution Time (ms) is %value%.
12.6.4 Aggregate Non Optimized Query Time (ms) Per Minute
This metric displays the total execution time, in milliseconds for queries that could not be resolved per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Non Optimized Query Time (ms) Per Minute is %value%.
12.6.5 Aggregate Optimized Queries Executed Per Minute
This metric displays the total number of parallel queries that were fully resolved using indexes per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Optimized Queries Executed Per Minute is %value%.
12.6.6 Average Optimized Query Execution Time (ms)
This metric displays the average duration, in milliseconds, for optimized query execution.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Average Optimized Query Execution Time (ms) is %value%.
12.6.7 Aggregate Optimized Query Time (ms) Per Minute
This metric displays the total execution time, in milliseconds for queries that were fully resolved using indexes per minute.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Optimized Query Time (ms) Per Minute is %value%.
12.7 Aggregate Query Optimization Metrics (Coherence version 3.7.1)
12.7.1 Maximum Query Duration (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.2 Aggregate Non Optimized Queries Executed Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.3 Average Non Optimized Query Execution Time (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.4 Aggregate Non Optimized Query Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.5 Aggregate Optimized Queries Executed Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.6 Average Optimized Query Execution Time (ms)
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.7 Aggregate Optimized Query Time (ms) Per Minute
All Versions
Every 5 Minutes
Not Defined
Not Defined
12.7.8 Aggregate Query Contentions Per Minute
This metric displays the aggregate number of times a query had to be reevaluated per minute due to concurrent updates.
All Versions
Every 5 Minutes
Not Defined
Not Defined
Aggregate Query Contentions Per Minute is %value%
