9 Glassfish Metrics
This chapter describes the Glassfish metrics.
9.1 EJB Cache Metrics by Server
This metric category provides information on EJB cache metrics by server.
9.1.1 Cache Hits (per minute)
This metric shows how many times per minute user requests on this server found a bean in the EJB cache.
Target Version Evaluation and Collection Frequency Default Warning Threshold Default Critical Threshold Alert Text
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of EJB cache hits is %value% (per minute).
9.1.2 Cache Misses (per minute)
This metric shows how many times per minute user requests on this server didn't find a bean in the EJB cache.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of EJB cache misses is %value% (per minute).
9.1.3 Cache Access Attempts (per minute)
This metric shows how many times per minute user requests on this server have attempted to access the EJB Cache.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of EJB cache access attempts is %value% (per minute).
9.1.4 Cache Hits (%)
This metric shows the percentage of user requests on this server that found a bean in the EJB cache.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The EJB cache hit rate is %value%%%.
9.2 EJB Pool Metrics By Server
This metric category provides information on the EJB Pool Metrics by Server.
9.2.1 Beans in Pool
This metric shows the number of EJBs deployed to this server that are currently in the associated pool, providing information about how the pool is changing.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of beans in pool is %value%."
9.2.2 Threads Waiting
This metric shows the number of threads waiting for free beans, giving an indication of possible congestion of requests.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of threads waiting for free beans is %value%.
9.3 JMS Connection Pool Metrics by Server
This metric category provides information on JMS connection pool metrics by server.
9.3.1 Connections in Use
This metric shows the number of JMS connections currently in use on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of JMS connections in use is %value%.
9.3.2 Connections Pending
This metric shows the number of JMS connection requests in the queues on this server that are waiting to be serviced.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of JMS connections pending is %value%."
9.3.3 Connections Acquired (per minute)
This metric shows how many times per minute a logical connection was acquired from a JMS connection pool on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of JMS connections acquired is %value% (per minute)."
9.4 JTA Metrics
This metric category provides information on JTA metrics.
9.4.1 Active JTA Transactions
This metric shows the number of transactions currently active on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of active JTA transactions is %value%.
9.4.2 Committed JTA Transactions (per minute)
This metric shows the number of transactions per minute that have been committed on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The committed transactions are %value% (per minute).
9.4.3 JTA Transaction Rollbacks (per minute)
This metric shows the number of transactions per minute that have been rolled back on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The transaction rollbacks are %value% (per minute).
9.5 JVM Metrics
This metric category provides information on JVM metrics.
9.5.1 Heap Usage (MB)
This metric shows the heap memory in megabytes used by the Java Virtual machine.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The heap usage is %value% MB."
9.5.2 Java Vendor
This metric shows the name of the Java Virtual Machine vendor.
Target Version Collection Frequency
All Versions
Every 15 Minutes
9.5.3 Java Version
This metric shows the version of the Java Virtual Machine.
All Versions
Every 15 Minutes
9.5.4 CPU Usage (%)
This metric shows the percentage of CPU time used by the Java Virtual machine.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The CPU usage is %value%%%.
9.5.5 Heap Usage (%)
This metric shows the percentage of heap memory used by the Java Virtual machine.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The heap usage is %value%%%."
9.6 JVM Class Loading
This metric category provides information about the JVM class loading metric.
9.6.1 JVM Class Loading - Classes Currently Loaded
This metric tracks and raises an alert when the number of classes currently loaded exceeds the defined thresholds.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of classes currently loaded is %value%.
9.7 JVM Compilation Metrics
This metric category provides information about JVM compilation metrics.
9.7.1 JVM Compilation - Compilation Time (since startup) (ms)
For the selected Java Virtual Machine (JVM), this metric shows the total time spent by the JVM in compilation. The value of the metric is in milliseconds and shows the time spent in compilation since the JVM was last started.
All Versions
Every 15 Minutes
9.8 JVM Garbage Collectors Metrics
This metric category provides information about JVM garbage collectors metrics.
9.8.1 Garbage Collector - Invocations (per min)
This metric is the number of times the garbage collector was invoked per minute during the last metric collection interval.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The invocations for garbage collector %Name% are %value% (per minute).
9.8.2 Garbage Collector - Invocation Time (ms)
This metric shows the average time ( in millisecs) spent per invocation of the garbage collector during the last metric collection interval.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The invocation time for garbage collector %Name% is %value% ms.
9.8.3 Garbage Collector - Old Heap Percent Free after GC (%)
This metric tracks and raises an alert when the percentage of the old heap free space after garbage collection is less than the percentage defined in the thresholds.
All Versions
Every 15 Minutes
Not Defined
Not Defined
Percent of old heap free after GC for garbage collector %Name% is %value%%%.
9.8.4 Garbage Collector - Old Heap size after GC (MB)
This metric tracks the size (in MB) of the old heap free space after garbage collection.
All versions
Every 15 Minutes
9.8.5 Garbage Collector - Percent Time spent (%)
This metric tracks and raises an alert when the percentage of time that the garbage collector spends in garbage collection exceeds the percentage defined in the thresholds.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The percentage of time garbage collector %Name% has spent in Garbage Collection is %value% (%).
9.9 JVM Memory Pools Metrics
This metric category provides information about JVM memory pools metrics.
9.9.1 Name
This metric shows the name of the JVM memory pool.
All versions
Every 15 Minutes
9.9.2 Type
This metric shows the type of the JVM memory pool.
All versions
Every 15 Minutes
9.9.3 Memory Pool - Current Usage (MB)
This metric shows the current memory usage (in megabytes) of the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
The memory usage for pool %Name% is %value% MB.
9.10 JVM Memory Usage Metrics
This metric category provides information about the JVM memory usage metrics.
9.10.1 JVM Memory - Heap Memory Usage (MB)
This metric shows the total heap memory (in megabytes) currently in use by the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
The heap memory usage is %value% MB.
9.10.2 JVM Memory - Non-Heap Memory Usage (MB)
This metric shows the total non-heap memory (in megabytes) currently in use by the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
9.10.3 JVM Memory - Objects Pending Finalization
This metric shows the number of objects pending finalization in the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of objects pending finalization is %value%.
9.11 JVM Runtime Metrics
This metric category provides information about the JVM runtime metrics.
9.11.1 VM Name
This metric shows the name of the selected Java Virtual Machine (JVM).
10gR3, 11g, 12c
Every 15 Minutes
9.11.2 VM Version
This metric shows the version number of the selected Java Virtual Machine (JVM).
10gR3, 11g, 12c
Every 15 Minutes
9.12 JVM Threads
This metric category provides information about JVM threads metrics.
9.12.1 JVM Threads - Active Daemon Threads
This metric shows the current number of active daemon threads in the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
9.12.2 JVM Threads - Deadlocked Threads
This metric shows the current number of deadlocked threads in the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
9.12.3 JVM Threads - Peak Threads
This metric shows the maximum (peak) number of threads started in this Java Virtual Machine (JVM) since the JVM was started.
All Versions
Every 15 Minutes
Not Defined
Not Defined
9.12.4 JVM Threads - Active Threads
This metric shows the current number of active threads in the selected Java Virtual Machine (JVM).
All Versions
Every 15 Minutes
Not Defined
Not Defined
9.13 Module Metrics by Server
This metric category provides information on module metrics by server.
9.13.1 Active Sessions
This metric shows the number of sessions currently active on the server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of active sessions is %value%."
9.14 Response
This metric category provides information on the Response metrics.
9.14.1 Status
This metric shows the status of the server as an integer. A value of "1" is up, and a value of "0" is down.
All Versions
Every Minute
Not Defined
0
MESSAGE="The GlassFish Server is down"
CLEAR_MESSAGE="The GlassFish Server is up"
9.15 Server Metrics
This metric category provides information on server metrics.
9.15.1 State
This metric shows the current state of the server as an integer. Possible values are as follows:
  • public static final int STARTING_STATE = 0;
  • public static final int RUNNING_STATE = 1;
  • public static final int STOPPING_STATE = 2;
  • public static final int STOPPED_STATE = 3;
  • public static final int FAILED_STATE = 4;
All Versions
Every 15 Minutes
Not Defined
Not Defined
The server state is %value%.
9.15.2 Start Time
This metric shows the time when the server was started.
The following table shows how often the metric's value is collected.
All Versions
Every 15 Minutes
9.16 Server Datasource Metrics
This metric category provides information on server datasource metrics.
9.16.1 Connections in Use
This metric shows the number of datasource connections currently in use by applications running on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The number of connections in use is %value%.
9.16.2 Connections Created (per minute)
This metric shows the number of physical datasource connections created per minute by the pools on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The connections created are %value% (per minute).
9.16.3 Connections Acquired (per minute)
This metric shows the number of logical datasource connections acquired per minute from the pools on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The connections acquired are %value% (per minute).
9.17 Server Servlet Metrics
This metric category provides information on server servlet metrics.
9.17.1 Request Processing Time (ms)
This metric shows the average amount of time in milliseconds it took to process a servlet request on this server, since the last collection.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The request processing time is %value% ms
9.17.2 Requests (per minute)
This metric shows the number of servlet requests processed per minute on this server.
All Versions
Every 15 Minutes
Not Defined
Not Defined
The requests processed is %value% (per minute).
