Use this command to send a customer-defined notification.
The user must be defined as a member of the primary group lsms.
None.
# Notify the Surveillance Monitor that a new customer-defined event has occurred $ $LSMS_DIR/survNotify 9001 SET "Job completed" Response Notes
This command has no output other than the prompt.
| Exit Code |
Cause |
Suggested Recovery |
| 1 |
Socket open error. |
Contact the My Oracle Support (MOS). |
| 2 |
Usage error. |
Correct the syntax. |
| 3 |
Unknown operation argument. |
Supply a valid operation argument. |
| This command is usually run by scripts; scripts should search for exit codes. When the command is run from the command line, the output indicates suggested recovery. |
