The LSMS is designed with a number of redundant systems (such as power feeds and CPUs) to enable a server to continue hosting the LSMS application even after some failures. For cases of double-faults or other failure conditions for which there is no designed redundancy, the LSMS is designed to automatically switch over from the active server to the standby server. These failure conditions fall into the following categories:
The LSMS HA daemons on the active and standby servers send each other heartbeats once every second. When a server detects a loss of 10 heartbeats in a row, the server concludes that the other server is no longer functional and does the following:
LSMS4015|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Heartbeat failure
Until the standby server returns to STANDBY state, automatic switchover is not possible, and if manual switchover is attempted, the lsmsmgr text interface displays a warning indicating that there is no standby mode and no action is taken.
Each server monitors itself for accessibility to its database. In addition, the standby server monitors whether the replication process running and whether its replication of the active server’s database is within a configured threshhold (the default is one day).
LSMS4007|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - DB repl error
In addition, the server does the following:
LSMS4000|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Switchover initiated
If switchover is successful, the following notification is posted:
LSMS4001|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Switchover complete
If switchover is not successful, the following notification is posted:
LSMS4002|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Switchover failed
LSMS4013|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Primary inhibited
LSMS4014|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - Secondary inhibited
Users have the option of defining any network interfaces (NPAC, EMS, and/or Application) as critical. For each network interface that the user defines as critical, the user defines one or more IP addresses to be pinged by each server every minute. (For information about how to define a network interface as critical, refer to the Configuration Guide.)
When a network interface is defined as critical, each server pings the first configured IP address every minute. If the ping fails and only one IP address has been defined for that network interface, the interface is considered to have failed. If the interface has additional IP addresses defined, the interface is not considered to have failed until all IP addresses have been pinged with no response.
When a network interface is considered to have failed, the server posts one of the following notifications that corresponds to the failed interface:
LSMS2000|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - NPAC interface failure
LSMS0001|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - EMS interface failure
LSMS4004|14:58 Oct 22, 2005|xxxxxxx|Notify:Sys Admin - APP interface failure
After the server posts the notification of interface failure, it does the following:
If the active server detects that a critical network interface has failed, the active server determines whether any critical network interfaces are considered to have failed on the standby server:
If any critical network interfaces are considered to have failed on the standby server, the active server continues in the ACTIVE state; it does not switch over.
If all critical network interfaces are responding to pings on the standby server, the active server switches over to the standby server and posts the following notifications:
If the standby server detects that a critical network interface has failed, it continues to operate in STANDBY state. Although automatic switchover is not performed in this case, it is possible to manually switch over to a standby server that has detected a critical network interface has failed.
