Setting the User Level Password Timeout Interval Using the GUI
Use the following procedure to set the system level password timeout using the
GUI
Log in to the
LSMS
Console
as a user in the
lsmsadm
or
lsmsall
group.
From the main menu, select
Admin
Password Timeout
User Level
Modify
Figure 1. Modifying the User Level Password Timeout Interval
Click
Modify
, and the
Modify User Level Password Timeout
dialog displays.
Figure 2. Modify User Level Password Timeout
Select a user whose password timeout interval you want to modify.
Type in the number of days for the password timeout interval, then click
OK
If you have successfully modified the password timeout, then the Update Successful dialog displays.
Figure 3. Update Successful
Click
OK
Parent topic:
Managing User Accounts on the Primary and Secondary Servers
