Terminating an Active User Session
Use the following procedure to terminate the session of an active
LSMS
GUI
User:
Log in to the
LSMS
Console
as a user in the
lsmsadm
or
lsmsall
group.
From the main menu, select
User/Session
Terminate User Session
Figure 1. Select
User/Session
After clicking
, the Terminate User Session dialog displays.
Figure 2. Terminate User Session Dialog
Click on the user session you want to end and click
Terminate
If you are sure you want to terminate the session, click
Yes
in the Confirm Delete dialog, otherwise click
No
Figure 3. Confirm Delete Dialog
After you successfully terminate a user session, click
OK
in the Delete Successful dialog.
Figure 4. Delete Successful Dialog
Parent topic:
Managing User Accounts on the Primary and Secondary Servers
