Use the lsmssurv status command to check the status of the Surveillance feature. This command allows you to determine if the Surveillance feature is already running or has already been stopped.
Log in as root on either server.
Type the following command to get surveillance status:
# lsmssurv status
You will receive one of the following messages:
LSMS Surveillance feature is currently started
LSMS Surveillance feature is currently stopped
Repeat this procedure for the other server, if desired.
