Creates or removes the regional NPAC database.
The user must be logged in with the user name lsmsadm.
This command must be run on each server.
If a database is in use by a regional LSMS agent, it cannot be removed.
If a regional database has already been created, it must be removed before it can be created again.
This command must be run from the $LSMS_DIR directory and run only from the primary server.
None.
# Create NPAC database for Canada region for the first time
------------------------------------------------------------------------- Npac Region Database Setup Script The Region Database Name is CanadaDB Initializing regional database...CanadaDB The regional database CanadaDB was created successfully. >> $LSMS_DIR/npac_db_setup remove Northeast
------------------------------------------------------------------------- Npac Region Database Setup Script The Region Database Name is NortheastDB Warning: NPAC region database CanadaDB is about to be removed. All data in the database will be lost. Do you want to continue? [Y/N]Y Removing regional database...CanadaDB >
This command takes approximately 35 to 40 seconds to execute.
| Exit Code |
Cause |
Suggested Recovery |
| 1 |
Syntax was incorrect |
Use correct syntax. |
| 2 |
MySQL command failed |
Contact Oracle. |
| 7 |
User attempted to create a database that already exists |
None needed. |
| 9 |
User attempted to remove a database that is in use |
Stop indicated processes before attempting to remove the database. |
| 10 |
The root user cannot execute this command |
Change users to lsmsadm. |
| 12 |
User attempted to remove database for an active region |
Make region inactive and retry command. |
