Using the
lsmsmgr
Interface to Determine the Server Status
Use the following procedure to determine the status of both servers.
Log into either server as the
lsmsmgr
user.
From the main
lsmsmgr
interface, select
Maintenance
LSMS Node Status
Figure 1. LSMS Node Status
In
Figure 6-2
, the server that was logged into is named
lsmspri
and its state is
ACTIVE
; the mate server is named
lsmssec
and its state is
STANDBY
Press any key to return to the
lsmsmgr
Maintenance menu.
Parent topic:
Managing Server States Manually
