Start MySQL Replication on Query Servers
Use the following procedure to start MySQL replication on the query server:
  1. Start the MySQL command-line utility on the query server:
    # cd /opt/mysql/mysql/bin
    # mysql -u root -p
    Enter password:
    <Query Server’s MySql root user password>
  2. Start MySQL replication:
    When the replication operation resumes, the slave server should connect to the master and catch up on any updates that occurred since the replication operation was terminated.
    mysql> start slave;
  3. Verify that MySQL replication is running using the show slave status command (ensure the Slave_IO_Running and Slave_SQL_Running column values are set to Yes, and ensure that the log file has a name).
    mysql> SHOW SLAVE STATUS \G;
  4. Exit the MySQL command-line utility:
    mysql> exit;
