All BDD file names include a creation timestamp, which is represented as <create>. Time Range BDD file names also contain start (<start>) and end (<end>) timestamps. All timestamps are represented as DD-MM-YYYYhhmmss where:
DD represents a two-digit day
MM represents a two-digit month
YYYY represents a four-digit year
hh represents a two-digit hour
mm represents a two-digit minute
ss represents a two-digit second
An example timestamp is 11-10-2006123015.
For Object Range BDD files, <start> is always 00-00-0000000000 and <end> is always 99-99-9999999999. These are the default values.
Table 1 references the pages where you can find information about file naming conventions for each data type:
| Type of Data File |
See: |
| Subscription Version (Object Ranges and Time Ranges are supported) |
| Number Pool Block (Object Ranges and Time Ranges are supported) |
| LRN, NPA-NXX, and NPA-NXXX (Only Objects are supported) |
| SPID (Only Objects are supported) |
The file name for subscription version files is represented as <NPANXX-NPANXX>, which indicates the range of NPA-NXX values contained in the download file. The file extension values depend on whether you are requesting a file for an Object Range BDD or for a Time Range BDD, as shown in Table C-2.
| Range Type |
Naming Convention |
| Object Range BDD |
<NPANXX-NPANXX>.<create>2.00-00-0000000000.99-99-9999999999 |
| Time Range1 BDD |
<NPANXX-NPANXX>.<create>.<start>.<end>2 |
| 1Time Range files are supported only if you have installed the NANC 3.2 feature 2For format of <create>, <start>, and <end>, see File Naming Conventions. |
Following are examples of uses for subscription version BDD files:
If you need to bulk download all subscription versions from the NPAC, use the following file name:
<000000-999999>.<create>.00-00-0000000000.99-99-9999999999
If you need to bulk download all subscription versions for a time period from midnight February 12, 2006 to midnight February 13, 2006 in a file created February 14, 2006 at 9:00 a.m., use the following file name:
<000000-999999>.14022006090000.12022006000000.13022006000000
If you need files to correct an NPA split, specify three Object Range files that have the same NPANXX values before and after the hyphen:
One file with the old NPANXX value
One file with the correct new NPANXX value
One file with the erroneous new NPANXX value
For example, if an NPA split was erroneously entered from 909-860 to 123-860 instead of correctly from 909-860 to 124-860, specify the following files:
909860-909860
124860-124860
123860-123860
Because no file extension is specified in these files, the default values of 00-00-0000000000.99-99-9999999999 are assumed.
The file name for number pool block files is represented as <NPANXXX-NPANXXX>, which indicates the range of EDR NPA-NXXX values contained in the download file. The file extension values depend on whether you are requesting a file for an Object Range BDD or for a Time Range BDD, as shown in Table C-3.
| Range Type |
Naming Convention |
| Object Range BDD |
<NPANXXX-NPANXXX>.<create>2.00-00-0000000000.99-99-9999999999 |
| Time Range1 BDD |
<NPANXXX-NPANXXX>.<create>.<start>.<end>2 |
These file types exist only if the NPAC supports Efficient Data Representation (EDR). Following are examples of uses for number pool block BDD files:
If you need to bulk download all number pool blocks from the NPAC, use the following file name:
<0000000-9999999>.<create>.00-00-0000000000.99-99-9999999999
If you need to bulk download all number pool blocks for a time period from midnight February 12, 2006 to midnight February 13, 2006 in a file created February 14, 2006 at 9:00 a.m., use the following file name:
<0000000-9999999>.14022006090000.12022006000000.13022006000000
If you need files to correct an NPA split, specify three files, each with the NPANXX value followed by a 0 before the hyphen and the NPANXX value followed by a 9 after the hyphen:
9098600-9098609
1248600-1248609
1238600-1238609
In contrast to SVs and NPBs data file types, there are a much smaller number of LRN, NPA-NXX, and NPA-NXX-X objects; therefore, ranges are not supported for these data file types, as shown in Table C-4.
The file name for LRN files is represented as <LRN>, which indicates the LRN value contained in the download file.
The file name for NPA-NXX files is represented as <NPANXX>,which indicates the NPA-NXX value contained in the download file.
The file name for NPA-NXXX files is represented as <NPANXX>, , which indicates the EDR NPA-NXXX value contained in the download file. This file type exists only if the NPAC supports Efficient Data Representation (EDR).
The file extension values depend on whether you are requesting a file for an Object BDD or for a Time Range BDD, as shown in Table C-4.
| Type |
Naming Convention |
| Object BDD |
<LRN>.<create>2.00-00-0000000000.99-99-9999999999 |
| <NPANXX>.<create>2.00-00-0000000000.99-99-9999999999 |
| Time Range1BDD |
<LRN>.<create>.<start>.<end>2 |
| <NPANXX>.<create>.<start>.<end>2 |
| <NPANXXX>.<create>.<start>.<end>2 |
| 1 Time Range files are supported only if you have installed the NANC3.2 feature 2 For format of <create>, <start>, and <end>, see File Naming Conventions. |
In contrast to SVs and NPBs data file types, there is a much smaller number of SPID objects; therefore, ranges are not supported for this data file type, as shown in Table C-5.
The SPID naming convention only applies to Object BDD files; Time Range is not supported. The file name for SPID files is represented as <SPID>, which indicates the SPID value contained in the download file..
| Type |
Naming Convention |
| Object BDD |
<SPID>.<create>2.00-00-0000000000.99-99-9999999999 |
Only the <create> timestamp field is supported.
