3000000000000001 – Server fan failure
Alarm Type: TPD
Description: This alarm indicates that a fan in the EAGLE fan tray in the EAGLE shelf where the E5-APP-B is "jacked in" is either failing or has failed completely. In either case, there is a danger of component failure due to overheating.
Severity: Major
OID: TpdFanErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.1
Alarm ID: TKSPLATMA13000000000000001
Recovery
  1. Run syscheck in Verbose mode to verify a fan failure using the following command:
    [root@hostname1351690497 ~]# syscheck -v hardware fan
    Running modules in class hardware...
             fan: Checking Status of Server Fans.
    *         fan: FAILURE:: MAJOR::3000000000000001 -- Server Fan Failure. This test uses the leaky bucket algorithm.
    *         fan: FAILURE:: Fan RPM is too low, fana: 0, CHIP: FAN
    One or more module in class "hardware" FAILED
    LOG LOCATION: /var/TKLC/log/syscheck/fail_log
  2. Refer to the procedure for determining the location of the fan assembly that contains the failed fan and replacing a fan assembly in the appropriate hardware manual. After you have opened the front lid to access the fan assemblies, determine whether any objects are interfering with the fan rotation. If some object is interfering with fan rotation, remove the object.
  3. Contact the My Oracle Support (MOS).
