When the SPID Security feature is enabled, this command allows a user logged in as lsmsadm to associate specified users to access data belonging to specified Service Provider ID (SPID).
The user must be logged in with the user name lsmsadm.
$ spidsec -d -u lsmsadm
lsmsadm GOLDEN# Authorize the username thomas to access the SPID TKLC
$ spidsec -a -u thomas -s TKLC
No output is displayed.
# Display the SPID security for all usernames$ spidsec -d
lsmsadm GOLDEN lsmsall GOLDEN lsmsuser GOLDEN lsmsuext GOLDEN lsmsview GOLDEN
thomas TKLC
None.
| Exit Code |
Cause |
Suggested Recovery |
| -1 |
Usage error. |
Correct the syntax. |
| 1 |
File access error. |
Contact the My Oracle Support (MOS). |
| 2 |
Database error. |
| 3 |
Invalid user. |
Change user to lsmsadm. |
| 4 |
Unknown error. |
| This command is usually run by scripts; scripts should search for exit codes. When the command is run from the command line, the output indicates suggested recovery. |
