To support user-based security for SNMPv3, LSMS provides the menu options. These menu options are accessible only when the SNMP Global Mode is set to SNMPv3 ONLY or Both. Following is an example of the initial Add menu.
The User Name must be unique, 1 - 50 alphanumeric characters in length, and is case sensitive.
The Group Name must be already configured to be specified for a user, and must exactly match (case sensitive) a configured group name.
Select or specify the Auth Protocol, Auth Password, Priv Protocol, and Priv Password fields as needed:
The Auth Password and Priv Password fields are encrypted in the database.
A user that is associated with any NMS cannot be deleted. For information about associating a user with an NMS, see NMS Configuration.
