Allows user to view security key status, load keys, or delete keys for NPAC associations.
keyutil
The user must be logged in with the user name lsmsadm.
$LSMS_TOOLS_DIR/keyutil -r <region> -k {public|private} [-d] [-l <filename>] [-x <listid>] [-s <listid>, <keyid>] [-y]
Customer ID: TKLC List ID: 1 Ok to make changes? y $
None.
None.
| Exit Code |
Error Message |
Cause |
Suggested Recovery |
| -1 |
SyntaxError |
The command was entered with incorrect syntax. |
Try the command again with correct syntax. |
| 1 |
FileError |
The key file to be opened could not be found. |
Verify the file path. If necessary, correct the path and try the command again. If the problem persists, contact the My Oracle Support (MOS). |
| 2 |
SaidNo |
User answered no when prompted for changes. |
No action necessary. |
| 3 |
NoKeysFound |
User specified keys to delete, but those keys were not found. |
Contact the My Oracle Support (MOS). |
| 4 |
DbError |
Database exception occurred; contact Oracle. |
| 5 |
InvalidUser |
A user who is not lsmsadm attempted to run this command. |
| 6 |
UnknownError |
Not known. |
