Creates or removes the resynchronization database.
The user must be logged in with the user name lsmsadm.
This command must be run on each server.
If the resynchronization database has already been created, it must be removed before it can be created again.
This command must be run from the $LSMS_DIR directory and run only from the primary server.
None.
This command takes approximately 35 to 40 seconds to execute.
None.
| Exit Code |
Cause |
Suggested Recovery |
| 1 |
Missing arguments. |
Use the correct syntax and supply all required arguments. |
| 3 |
Executing command from wrong directory. |
Change directory to $LSMS_DIR. |
| 6 |
Invalid action argument. |
Use the correct syntax and supply a valid action argument. |
| 7 |
Database already exists. |
No action necessary. |
| 8 |
Database exists on another host. |
| 9 |
Database in use by process. |
Stop the process that is using the database. |
| 10 |
User is not authorized to use this command. |
Change user to lsmsadm. |
| 11 |
Command executed on secondary server. |
Execute command on the primary server. |
| This command is usually run by scripts; scripts should search for exit codes. When the command is run from the command line, the output indicates suggested recovery. |
