Check MySQL Replication Status on Query Servers
Use the following procedure to check MySQL replication status on query servers:
  1. Start the MySQL command-line utility on the slave server:
    # cd /opt/mysql/mysql/bin
    # mysql -u root -p
    Enter password:
    <Query Server’s MySql root user password>
  2. Check the replication status using the show slave status command (the status of the slave server is conveyed by the Slave_IO_Running and Slave_SQL_Running column values):
    mysql> SHOW SLAVE STATUS \G;
