Table 1 shows a summary of privileges allowed to each user type.
| User type |
Privileges |
User secondary group name |
SPID value for logging in |
| System Administration User |
Allows the user to inherit all the privileges of all other user types |
lsmsall |
NPAC-assigned SPID (refer to the Configuration Guide). |
| System Configuration User |
Allows the user to:
lsmsadm |
| Database Administration User |
Allows the user to:
lsmsuser |
Any SPID. If a shadow LSMS exists, use the same SPID for similar functions on main and shadow LSMS. |
| External User |
Allows the user the same access as lsmsuser, but the user is not permitted access to the NPAC menu on LSMS GUI |
lsmsuext |
| Viewer User |
Allows the user:
lsmsview |
Any SPID. |
Table 2 shows the commands each user type has permission to execute. For more information about the commands, see Commands.
| Command | root | lsmsadm | lsmsuser | lsmsview | lsmsall | lsmsuext | |
| Command permissions: X = Users in this group have permission to use this command. lsmsadm = The user must be logged in with the name lsmsadm to have permission to use this command. root = The user must be logged in with the name root to have permission to use this command. |
| autoxfercfg |
X |
| chglct | X |
| chkfilter | X |
| eagle | lsmsadm |
| import |
X |
X |
X |
X |
X |
| keyutil | lsmsadm |
| lsms |
lsmsadm |
| lsmsdb | root |
X |
X |
X |
X |
X |
| lsmsSNMP |
X |
| lsmssurv |
root |
| massupdate | lsmsadm |
| measdump |
X |
X |
X |
X |
| npac_db_setup |
lsmsadm |
| npacimport | lsmsadm |
| report |
X |
X |
X |
X |
X |
| resync_db_setup |
lsmsadm |
| SAagent |
X |
| spidsec |
lsmsadm |
| sup |
lsmsadm |
| sup_db_setup |
lsmsadm |
| survNotify |
root |
X |
X |
X |
X |
X |
| syscheck |
root |
For information about the GUI functions each permission group can access, refer to the tables in the Configuration Guide (Admin GUI Access, Configure User Access, and Keys GUI Access) and the Database Administrator's Guide (User/Session GUI Access, NPAC GUI Access, LSMS GUI Access, Reports GUI Access, Logs GUI Access, and Popup Menus GUI Access).
