The LSMS’s NTP client daemon expects that the LSMS system time has been set close to the real time. If the reference time received from the NTP server is significantly different from the LSMS system time, the daemon waits up to twenty minutes until it sets the time. However, if the reference time is off more than about twenty minutes (which is rare), the daemon terminates and does not set the system time.
If you think that the daemon may have terminated, perform the following procedure:
