Run this command to verify that EMS Routing is set up properly. This command reviews all the telephone number (TN) and number pool block (NPB) transactions that were received from NPACs in the past 24 hours and determines whether any of these TNs and NPBs were not forwarded to any EAGLE node. If any are found, a file $LSMS_DIR/../logs/trace/LsmsSubNotFwd.log.<MMDD> (where <MMDD> indicates the month and day the chkfilter command was run) is created and those TNs and NPBs are stored in this file.
chkfilter
The user must be logged in with the user name lsmsadm.
$LSMS_TOOLS_DIR/chkfilter
None.
None.
| Filename |
Type |
Location |
| LsmsSubNotFwd.log.<MMDD> |
$LSMS_DIR/../logs/trace/ |
None.
| Exit Code |
Error Message |
Cause |
Suggested Recovery |
| -1 |
Syntax error |
User entered command with incorrect syntax. |
Try the command again with correct syntax. |
| 1 |
DbError |
Database exception. |
Contact the My Oracle Support (MOS). |
| 2 |
InvalidUser |
A user with a username other than lsmsadm attempted to run this command. |
Log in as lsmsadm and try the command again. |
| 3 |
EnvNotSet |
The LSMS_DIR env variable is not set. |
Verify the environment variables. |
| 4 |
FileError |
Unable to open output file, check directory and permission |
| 5 |
UnknownError |
Not known. |
