chglct
Change Last Change Time
Manually sets the Last Change Time (LCT) for the database belonging to the specified region.
In each regional database, the LSMS updates the LCT when the LSMS receives transactions from that NPAC. When the LSMS automatically recovers from a temporary loss of association with an NPAC, it uses the LCT to determine the time range for which to request that the NPAC resend transactions.
Use this command to manually set the LCT when performing a bulk download of files from the NPAC (see “NPAC-LSMS Download Procedure”, 32
Keyword
chglct
Permission
The user must be logged in with the user name lsmsadm.
Syntax
$LSMS_TOOLS_DIR/chglct -h -r <region> [-d|-s <YYYYMMDDhhmmss>]
Options
-h
Displays help information
-r <region>
Display or set the LCT in Greenwich Mean Time (GMT) for the region specified by <region>. Possible values for <region> are:
  • Canada
  • Midwest
  • MidAtlantic
  • Southeast
  • Southwest
  • Northeast
  • Western
  • WestCoast
-d
Display the current value of the LCT (in GMT) value for the specified region. The value has 14 characters in the form YYYYMMDDhhmmss which has the format shown in Table 1.
-s <YYYYMMDDhhmmss>
Set the value of the last change timestamp (in GMT) value for the specified region to the value indicated by the specified character string, which has 14 characters in the form YYYYMMDDhhmmss.
Table 1. Time Value for chglct
Characters
Meaning
Range
YYYY
Year
Any four digits
MM
Month
01–12
DD
Day
01–31
hh
Hour
00–23
mm
Minute
00–59
ss
Second
00–59
Sample Output
Display the last changed timestamp for the Midwest region
$ chglct -d -r Midwest
Midwest last changed timestamp: 20011107113017
Local Time: 11/7/2001 6:30:17
GMT Time: 11/7/2001 11:30:17
Related Commands
None.
Response Notes
None.
Possible Errors
Table 2. Error Messages: chglct
Exit Code
Error Message
Cause
Suggested Recovery
-1
Syntax error
User entered command with incorrect syntax.
Try the command again with correct syntax.
1
DbError
Database exception.
Contact the My Oracle Support (MOS).
2
InvalidUser
A user with a username other than lsmsadm attempted to run this command.
Log in as lsmsadm and try the command again.
3
UnknownError
Contact Oracle.
Files
None.
